shane92g Posted November 24, 2013 Share Posted November 24, 2013 How do you replaced the trunk lock bezel on the 71/72 as this does not look like a simple task... Link to comment Share on other sites More sharing options...
Sam (Bones) Posted November 24, 2013 Share Posted November 24, 2013 actually it is very easy get a flashlight and you'll see the nuts that secure from the back side Link to comment Share on other sites More sharing options...
stangeba Posted November 24, 2013 Share Posted November 24, 2013 Sam, It's been a few years but I just gently pried mine off. There are three (or four) inserts that fit into the trunk lid. They are like the inserts that are used on the sail panel Monte Carlo script. 71 built in Oshawa May of 71. No nuts on mine. Bruce Link to comment Share on other sites More sharing options...
Sam (Bones) Posted November 24, 2013 Share Posted November 24, 2013 Hmmmm, I have to open the trailer up, I thought mine had the pressed sheet metal nuts on them Link to comment Share on other sites More sharing options...
Sam (Bones) Posted November 24, 2013 Share Posted November 24, 2013 Hmmmm, I have to open the trailer up, I thought mine had the pressed sheet metal nuts on them anyway if you look from the inside with a flashlight you'll be able to tell Link to comment Share on other sites More sharing options...
7tonemonte Posted November 24, 2013 Share Posted November 24, 2013 From my memory it was barrel nuts like Bruce said. It's been a while since I put it on though. Basically pry gently with something (not a screwdriver) that won't scratch the deck lid. Link to comment Share on other sites More sharing options...
shane92g Posted November 24, 2013 Author Share Posted November 24, 2013 I can't see how to get at the lock fastners under the trunk lid. I only see one Philip screw hold a small some triangular metal piece however I think that's to hold the lock assembly in place. Link to comment Share on other sites More sharing options...
shane92g Posted November 24, 2013 Author Share Posted November 24, 2013 Is there a plate that needs to be remove Link to comment Share on other sites More sharing options...
footballubet Posted November 24, 2013 Share Posted November 24, 2013 For the bezel just pry it off. Barrel clips hold it in place. That triangle piece needs to be pulled down only if you are replacing the lock or latch. Link to comment Share on other sites More sharing options...
shane92g Posted November 24, 2013 Author Share Posted November 24, 2013 Thanks Scott, will try that... Link to comment Share on other sites More sharing options...
Leghome Posted November 24, 2013 Share Posted November 24, 2013 I use two putty knives. One to pry with and one to protect the paint. Link to comment Share on other sites More sharing options...
shane92g Posted November 24, 2013 Author Share Posted November 24, 2013 I use two putty knives. One to pry with and one to protect the paint. Hmm, thank you I was wondering the best way to attack the prying step without scratching the paint Link to comment Share on other sites More sharing options...
