Wv Wild 72 Monte Posted February 9, 2014 Share Posted February 9, 2014 Hi Guys, Im pretty new here. My 72 monte W/A/C. Heater blower motor wont blow, does have power and motor is good. I was told that the 4 season relay is bad? Could this be true? Thanks.. Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 9, 2014 Share Posted February 9, 2014 if you have power at the motor, is the ground strap connected? the motor must be grounded because the AC case is not steel Link to comment Share on other sites More sharing options...
Wv Wild 72 Monte Posted February 9, 2014 Author Share Posted February 9, 2014 Ok, I will check taht too. I did pull some of the wiring, on passenger side at the top of the firewall, under the hood, above the A/C box, and it worked for a moment. There was a fusable link there and the wiring looked nasty. I am going there also and put new fusable link wire and see if that helps. Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 9, 2014 Share Posted February 9, 2014 then the ground is good, your issue is in that wiring Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 9, 2014 Share Posted February 9, 2014 OH!!!! and welcome! Link to comment Share on other sites More sharing options...
Patrick Sheean Posted February 9, 2014 Share Posted February 9, 2014 Hi Guys, Im pretty new here. My 72 monte W/A/C. Heater blower motor wont blow, does have power and motor is good. I was told that the 4 season relay is bad? Could this be true? Thanks.. The 4 seasons relay only controls the high speed setting on the blower. I agree with Sam sounds like a wiring issue. Link to comment Share on other sites More sharing options...
Wv Wild 72 Monte Posted February 9, 2014 Author Share Posted February 9, 2014 Yeah, kinda think so too. Im going to pull all that wiring out and follow. I have a 2.5" thick build manuel from GM. Im going to get it out and see what all that wiring go to tomm. Thanks guys. Link to comment Share on other sites More sharing options...
footballubet Posted February 9, 2014 Share Posted February 9, 2014 Welcome aboard! You have to remember this wiring is over 40 years old. Could be broken wires inside the insulation and can't be seen. Try to pinpoint the area before tearing it all out. Or you could use an Ohm meter after it's out. Link to comment Share on other sites More sharing options...
Rob Peters Posted February 9, 2014 Share Posted February 9, 2014 Welcome aboard the boards, where in West Virginia are you located. I agree with trying to locate the problem wire ore wires . When you wiggle the wires you said iworked a little. If you wiggled them near a connector it could indicate a bad connection or some corrosion inside the connector and just require a good cleaning of the connection rob Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 9, 2014 Share Posted February 9, 2014 does any of the speeds work? a 12 volt test light is my tool of choice will working on wiring, "HI" will run thru the relay, all other speeds run thru the resistor block that is mounted in the AC case Link to comment Share on other sites More sharing options...
footballubet Posted February 9, 2014 Share Posted February 9, 2014 The best tool is a new style headlight bulb with jumper leads attached. A 194 bulb will light up with very minimal voltage. When you are dealing with possible corrosion or broken wire strands it's best to "put a load" on the wire. The headlight bulb will be dim if there is a problem in the wiring. I have been burnt on this a couple times before. Have learned the hard way. Link to comment Share on other sites More sharing options...
Wv Wild 72 Monte Posted February 19, 2014 Author Share Posted February 19, 2014 Hey Rob, Sorry for the late post. Been working doubles, and it's wearing out. Anyway, I live in Kearneysville. It's about 45 mins form PA. and 25 Mins from fredrick Md. Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted February 19, 2014 Share Posted February 19, 2014 to FGMCC! I am from Frederick, MD and hope to meet you one day Rick Link to comment Share on other sites More sharing options...
Wv Wild 72 Monte Posted February 19, 2014 Author Share Posted February 19, 2014 Where in Fredrick? Im 25 mins out. in between Charlestown and Martinsburg. Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted February 21, 2014 Share Posted February 21, 2014 I live 15 min west of downtown Frederick in Clover Hill area past Fort Detrick. Link to comment Share on other sites More sharing options...
JG72 Posted November 23, 2017 Share Posted November 23, 2017 Where is that relay located for the high setting for the blower motor? Thanks! Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted November 23, 2017 Share Posted November 23, 2017 On my 72, the blue area circled in pic is my high speed blower motor relay. I believe all 1st Gens with A/C were located same place. Doug 1 Link to comment Share on other sites More sharing options...
