LostnFound Posted April 1, 2014 Share Posted April 1, 2014 I thought these are a cool idea but meant for doing a full body off resto.... http://losangeles.craigslist.org/lac/pts/4400860618.html Link to comment Share on other sites More sharing options...
monte0 Posted April 2, 2014 Author Share Posted April 2, 2014 This gives you a little better idea as to how I did mine. I screwed 2 2x4's together for both beams. I jacked the body up on the reinforcements underneath. I had to use blocks of wood to get the body high enough. I lifted the front some, then the back. Kept going back and forth to keep the body level. When I set the body down I put small pieces of wood on the reinforcements and set those onto the beams. I added casters to the frame so I could roll it in and out of the garage. Just take your time and double check what you are doing. So you had no issue's with the pinch welds getting damaged at all? Link to comment Share on other sites More sharing options...
monte0 Posted April 2, 2014 Author Share Posted April 2, 2014 I thought these are a cool idea but meant for doing a full body off resto.... http://losangeles.craigslist.org/lac/pts/4400860618.html That would never fit in my garage...lol Link to comment Share on other sites More sharing options...
Dans '70 Z20 Posted April 2, 2014 Share Posted April 2, 2014 One of these mght fit LOL Auto Rotisserie Link to comment Share on other sites More sharing options...
footballubet Posted April 2, 2014 Share Posted April 2, 2014 I didn't set it on the pinch welds. I used 2x4 blocks on the floor reinforcements. Link to comment Share on other sites More sharing options...
LostnFound Posted April 2, 2014 Share Posted April 2, 2014 One of these mght fit LOL Auto Rotisserie SWEET! Same old problem though....$1700 buys a lot of Monte parts. Also, what do you do with the rotisserie when you are done the car? Maybe purchasing a good used one would be the way to go if you could find one. Link to comment Share on other sites More sharing options...
VETTEWITHLEGS Posted April 4, 2014 Share Posted April 4, 2014 YOU USE IT ON THE NEXT MONTE!....OF COURSE!! DUH! JIM Link to comment Share on other sites More sharing options...
monte0 Posted April 8, 2014 Author Share Posted April 8, 2014 Old frame is out and new one is ready, now if the weather will stop raining. And I did successfully get the frame out with the nose on still. Had to make it work since I'm seriously out of room in my garage...lol Link to comment Share on other sites More sharing options...
Sam (Bones) Posted April 8, 2014 Share Posted April 8, 2014 pictures??? Link to comment Share on other sites More sharing options...
footballubet Posted April 8, 2014 Share Posted April 8, 2014 Old frame is out and new one is ready, now if the weather will stop raining. And I did successfully get the frame out with the nose on still. Had to make it work since I'm seriously out of room in my garage...lol You are braver than me with leaving the front clip on! Link to comment Share on other sites More sharing options...
Rob Peters Posted April 8, 2014 Share Posted April 8, 2014 Congrats. Like Sam said, Pictures. It is not uncommon to see pictures of a Monte with the front clip removed and the body still on but can't say I have ever seen it in reverse. Rob Link to comment Share on other sites More sharing options...
Dans '70 Z20 Posted April 8, 2014 Share Posted April 8, 2014 On Long Island this is how we do a frame off. - Alert the troops of the day (Usually 10 guys is fine) - Purchase Donuts/Coffee or Case of beer depending on day/time - Have car unbolted from chassis and set to go - Wait for snowfall (happened for two of em)…… then shovel & salt driveway - Five guys on each side and Steve (project manager LOL) with a bull horn! JK - Prepare for sychnonized lifting (realize we forgot to take a prophylactic dose of Ibruprofen) …… and lift. - We walk body off frame and set her down on a wooden dolly Steve has made out of 4x4's. He made dolly so 4x4's run exactly where chassis would set, with 4x4's running side-to-side to hold everything together. Like Scott he added wheels to the dolly so body can easily be rolled around. Make sure you secure them well. If you hit the lip of you driveway apron with all the weight of the body they can tear off easily and scare the s#@&! oughta you. Dan Link to comment Share on other sites More sharing options...
monte0 Posted April 8, 2014 Author Share Posted April 8, 2014 lol, I was nervous but it is doable as long as you pull most the weight off the nose. And the steel inner wheel wells help I'm sure with the strength. Here's the pictures of my serious lack of room And the old frame And new frame Link to comment Share on other sites More sharing options...
monte0 Posted April 8, 2014 Author Share Posted April 8, 2014 Hey off topic, any of you guys interested in the old frame? It's clean but has some damage to it, and that was the reason I changed it. Link to comment Share on other sites More sharing options...
Boots Posted April 9, 2014 Share Posted April 9, 2014 serious lack of room???? lol...I've been working on my car in a plastic portable garage shelter in my driveway through out the winter..and it was a cold one this year...wish I was as far ahead as you are...cheers Link to comment Share on other sites More sharing options...
monte0 Posted April 12, 2014 Author Share Posted April 12, 2014 Ok, now that I'm into it this far I went even farther and started doing the floors too before the frame goes back in Here's the progress, I only got to the rear hump at the rear end. Going to continue on tomorrow more Link to comment Share on other sites More sharing options...
monte0 Posted April 12, 2014 Author Share Posted April 12, 2014 Did this all by hand with wire wheel and scraper on my back...not fun Link to comment Share on other sites More sharing options...
cny first gen 71 Posted April 12, 2014 Share Posted April 12, 2014 Wow that looks good, thats a lot of work any way you look at it. Link to comment Share on other sites More sharing options...
monte0 Posted April 12, 2014 Author Share Posted April 12, 2014 I'm not liking it but figured frames out and might as well Link to comment Share on other sites More sharing options...
Patrick Sheean Posted April 12, 2014 Share Posted April 12, 2014 What's not to like, it looks great to me Link to comment Share on other sites More sharing options...
monte0 Posted April 12, 2014 Author Share Posted April 12, 2014 Lol..the hours of dust, dirt and over spray all over me Link to comment Share on other sites More sharing options...
LostnFound Posted April 12, 2014 Share Posted April 12, 2014 Awesome! You'll be glad you addressed the bottom while it was off the frame. Good job! Link to comment Share on other sites More sharing options...
black07ss Posted April 12, 2014 Share Posted April 12, 2014 Looks great!! I am looking forward to the flatness of the floorboards after just completing the left wheel house Link to comment Share on other sites More sharing options...
monte0 Posted April 12, 2014 Author Share Posted April 12, 2014 Well looks like progress is halted. Compressor died so got to get it back up and running Link to comment Share on other sites More sharing options...
overdrive Posted April 14, 2014 Share Posted April 14, 2014 Nice job! Dan Link to comment Share on other sites More sharing options...
