Sign in to follow this
Wheel terms
Hey all, i am wondering if some one could tell me what all the terms involved with identifing a wheel and possible what ranges will fit on a monte. Im talking about offset and backspacing......etc.
Andrew
http://andrew72monte.tripod.com/
Share this post
Have installed 15x8s (offset stock: 4" or 4 1/4") Corvette Rallys on rear without quarter panel interference. Car has new rear springs and probably is near 1" higher than stock. Run'n 255x60x15 rear tires. Ed
'71 Black 406/700R4/10bolt, Branson participant
'71 Sandalwood SS454
'71 Project Darkest of Dark Green Metallics/GenIII346LS1/4L65E/12bolt posi
Share this post
Andrew,
You can fit a rim with 5.5" BS on the rear but do not want to go past 4.5 on the front
Ideally IMO the perfect rear wheel combination is a 15x8 with a 5" BS and a 275/60/15 tire. Wheel Vintiques sells 15x8 raqlleys with 5" BS. I have 2 of these and used them to run BFG Drag Radials 5 years ago. They fit perfect with a 275/60/15.
Right now I run 15x10 with 5.5 BS to fit as big a tire I can under there. I did have to trim the lip and the chrome moulding to fit the 13.5" section width in there.
a 225/70/15 on the front works great with a 15x7 ralley with 4 1/4 to 4 1/2 BS
If you have anymore specific questions please don't hesitate. I have used just about every combination of rims and tires on my Montes.
'71 Monte - NA, 10.78 @ 125mph, 3.42 gears, pump gas driver.
Share this post
mc71454, Is it possible to run a rear 15x10 with greater than 5.5BS and avoid trimming
the quarter panel lip and chrome? Thanks, Ed
Share this post
Ed,
the 5.5 is pretty close to the shock mount. If you relocate the shock mount and trim the old mount it may work with the inside of the wheel well opening. BUt you have to account for manufacturing tolerances including the centering of your rear in the car.
Also For example: Centerline uses whole number Back spacings but their 5" BS actually measures 4 7/8" so their 6" may be 5 7/8" or 5 3/4"
I had to trim for the Hoosier QT Pro's I use at the track where more tire the better.
what is your intended use?
Tom
Share this post
im looking to run a 15x10 wheel and the widest tire i can fit without trimming. what should i use? (need tire size in 28x??x15
Share this post
had a set of 15x10 rally wheels with 295/50 on them 5" backspacing had to trim the quarter panle lips a lil. now im runin 16x8 chrome rallys with 255/50 on the back. if u can find a 15x10 rim with a 4" or 4.5" backspacing u might not have to trim the quarter panle. the 15x10 that were on my monte is on a 57 nomad and we cut the spot welds and kncoked the hub out about a .5" to 1".
robert
projects
1957 nomad
1970 monte carlo body and paint work
Share this post
71Monte402.
run a 15x10 with 5.5 BS (Weld and Cragar) and a 28x11.50x15 Hoosier QT Pro.....OR...the same rim with a 28x10.5x15 MT ET Street.
Share this post
Im running cragar street stars 15x7 bs is 4.125 and I have P275/60/15 They dont rub and they tuck under the wheel wells nicely.
Share this post
I am going for the look of really really wide tires in back and a bit smaller in teh front, but i dont want to alter my quarter pannels. If you know what would satisfy my want id be glad to hear it.
Andrew
Share this post
Andrew,
A 15x10 with a 5.5" BS with a 295/50/15 tire will likely work. That's what I run for a street tire in the back and a 215/70/15 in the front has a nice stance to it without getting too narrow in the front. I like it to still handle decently and our Montes are pretty heavy in the front.
I can measure how much room I have to the fender lip with the 295's on there and let you know tomorrow.
Too bad you couldn't make it over to my house and try on one of the wheels.
here is a pic from the back.
Share this post
That is exactly the look im after. If i could fit those big wheels without trimming anything i would be very happy!!!
And i think i understand now with that pic thanks a lot
[This message has been edited by Andrew72 (edited 10-08-2003).]
Share this post
speaking of tires, I have an interesting situation
I have 240/55-415 wheels and tires
yes I know, they're wierd
they're metric TRX wheels
415mm diameter = 16.3 inches roughly, and I really like how the size looks with the car, so I was thinking about a 245/55-16 wheel and tire .. they're reasonably afordable heh
think this size sounds like it might look alright:? smile.gif
http://www.bizarreideas.com/panasonic/kc8oye/Outside/side.jpg
Share this post
