Big block fan shroud, Head light rings
Hey guys I am looking around for a big block fan shroud and the chrome head light rings. Is there anywere that sells new or do any of you have some in good condition. Thanks guys.
The Chevelle shroud is the same piece. The only thing you will need to do or have, is a good extension from your existing shroud. Monte Big block and small block shroud extension are the same, only the part that mounts to the radiator is different. As far as getting the shroud, the Chevelle piece is being repoduced. From the factory the extension was held on by large staples, all I did to attach the two piece's was to drill a series of holes around the perimeter (5 or 6) and used plastic push pins (found at any body shop supply) to hold it together.
Good Luck, Steve
www.geocities.com/monteman1971
