stall speed
bustoff
I installed a 468 with a 3000 stall conv now my trans is shifting soft my question is does the 3000 stall converter change the way it shifts ? ( before I was running 402 with the same th400 (no stall) and getting very firm shifts ( rubber ) now soft shifts )
  • 6 months later...
Yep. Higher stall means increased slippage (the trans shifts just as quick as before but the high stall takes out the harshness) and it also reduces the engine braking effect. On the freeway off-ramp mine used to slow down pretty quick by just lifting off of the pedal... now it feels almost like it's in neutral.
