Grease Posted October 22, 2000 Share Posted October 22, 2000 ok opening up tranny talk . not sure if this is correct ? for this forum . have any of you swapped in a 700r4 ? what problems mite i be expecting in a s/b 70 monte . i know i need a kit for lockup converter, anything else i should consider? i also have floor shift if that complicates the swap. thanks mike Link to comment Share on other sites More sharing options...
ejw71 Posted October 22, 2000 Share Posted October 22, 2000 I'm going to install a 700R4 in my '71/350. I've determined that the trans mount will be 2 1/8th inches further rearward. This is easily changed on the existing cross member. The lockup feature wil be set internally, thereby eliminating an external switch. Driveshaft changes depends trans being from a Chevy or from a Corvette. Try tciauto.com for transmission dimensions. Link to comment Share on other sites More sharing options...
Andreas Posted October 23, 2000 Share Posted October 23, 2000 Here is an excellent website for all your questions on trannys and tranny swaps: http://www.442.com/oldsfaq/oftrn.htm Link to comment Share on other sites More sharing options...
ejw71 Posted November 8, 2000 Share Posted November 8, 2000 I intend to (hope to)use the column shifter for the 700R4. Check out www.shiftworks.com for changing over to later model quadrant. Link to comment Share on other sites More sharing options...
Guest Posted November 13, 2000 Share Posted November 13, 2000 here's another resourse; www.thegrid.net/thedrivetrainpage/700inst.htm ------------------ J.J.Gerena Link to comment Share on other sites More sharing options...
Grease Posted November 13, 2000 Author Share Posted November 13, 2000 thanks folks for all the tips and info i ll be reading up on this now and getting ready to do this .maybe around Christmas mike Link to comment Share on other sites More sharing options...
