TRANSMISSION- 700r4 swap!
Grease
ok opening up tranny talk . not sure if this is correct ? for this forum . have any of you swapped in a 700r4 ? what problems mite i be expecting in a s/b 70 monte . i know i need a kit for lockup converter, anything else i should consider? i also have floor shift if that complicates the swap. thanks mike
I'm going to install a 700R4 in my '71/350.
I've determined that the trans mount will be 2 1/8th inches further rearward. This is easily changed on the existing cross member.
The lockup feature wil be set internally, thereby eliminating an external switch. Driveshaft changes depends trans being from a Chevy or from a Corvette. Try tciauto.com
for transmission dimensions.
  • 3 weeks later...
thanks folks for all the tips and info i ll be reading up on this now and getting ready to do this .maybe around Christmas mike
