another rear brake conversion question!
bodene
if I buy master cylinder and booster kit for front and rear disk do I still need to change portioning valve for rear disk also or does master cylinder take care of that and all I need is distribution valve?
yes you still need to change the prop valve or the rear brakes wont get enough pressure to work right and u will keep bleeding them tryin to get them to work..and by the way a prop valve and a distribution valve are the same thing
