anthony_72monte Posted September 13, 2016 Share Posted September 13, 2016 i would like to turn my 72 column shift into floor shifter( maybe a 4 speed ?) links or how to guides or parts list would be appreciated. Quote Link to comment Share on other sites More sharing options...
John S Posted September 13, 2016 Share Posted September 13, 2016 http://www.leverfamilysite.com/images/PDF_Files/How_To_Install_Bucket_Seats_and_Console.pdf This may help. There also was some info on a chevelle forum. Quote Link to comment Share on other sites More sharing options...
anthony_72monte Posted September 13, 2016 Author Share Posted September 13, 2016 Thanks a lot I appreciate the help!! I hear the 69-70 chevelles fit the Monte Carlos ? Quote Link to comment Share on other sites More sharing options...
Clever Idiot Posted September 15, 2016 Share Posted September 15, 2016 This walk-through is fantastic. Quote Link to comment Share on other sites More sharing options...
cbolt Posted September 16, 2016 Share Posted September 16, 2016 I hope this attachment works. It has the same illustrations but more clear, and measurements at the end. I did this swap a little over a year ago using only this reference.... All the info I needed. console_install.pdf Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted September 16, 2016 Share Posted September 16, 2016 The 70-72 Chevelle/ Elcamino consoles would be more correct for the 70-72 Monte Carlo, but the 68/69 Chevelle/ Elcamino consoles will also work. They just have some cosmetic differences. Such as the seat belt stowage clips verses rubber seat belt pockets. The console compartment lids/ doors are also different. The 4 speed shifter plate was the same from 68-72. Quote Link to comment Share on other sites More sharing options...
mymontesa70 Posted September 17, 2016 Share Posted September 17, 2016 nice walk through. Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted September 30, 2016 Share Posted September 30, 2016 You will need to find bucket seats, and a floor shift column, also change the speedometer face to name a few more things Quote Link to comment Share on other sites More sharing options...
cbolt Posted October 1, 2016 Share Posted October 1, 2016 Also you will need at a minimum a console extension wiring harness. Mine required a dash harness as well because my original harness did not have the pigtail for the console. I was told by various folks that all the harnesses were the same and I wouldn't need a dash harness. Well let me tell you that after ripping my harness out of the car I discovered that wasn't at all true. The console car harness will have a connector for the console about midway across the dash. There is a chance your car has this connector, but it isn't guaranteed. Of course, in order to make all the lights work (and the nss function) you could also jumper into the door light switch wiring, but I wanted to make mine without splices or anything creative in case 50 years from now someone else gets behind the dash for whatever reason. They will have a vehicle which is accurate per the schematics. Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted October 1, 2016 Share Posted October 1, 2016 Unless a console was ordered chances are you will not have the connector for the console extension. Quote Link to comment Share on other sites More sharing options...
