TH 400 kickdown switch bracket
beater72
If I remember correctly, on my 72, the bracket that holds the gas pedal linkage on also functions as the TH400 Kick Down Switch Bracket.
I only have a partial picture that I can find as the upper portion of the bracket is out of site.  I can't say the 70/71 models followed same method.
Basically, should be able to bolt kick down switch right onto the bracket holding the gas pedal linkage in place.
Doug
The reason I ask if this part is adjustable ,is that when I mash on the gas sometimes the switch engages for a shift down to lower gear and sometimes it does not, I did about 20 years ago put a piece of rubber hose on the part that touches the gas pedal bracket ,and it worked fine ,now I changed the switch to new and still does kick down to lower gear only sometimes,thanks
