MC1970U Posted January 20, 2017 Share Posted January 20, 2017 I need to address the dim headlights on the Monte Carlo. I have read all the headlight topics in our forum but most are pretty old and wanted to know what the current thoughts are. I have some halogens in there now but they are pretty old and I have no idea how well they are working. Just want to brighten things up as much as possible legally. I was thinking about the setup Doug did in this thread http://www.firstgenmc.com/forums/index.php?/topic/14184-headlights-stock-replacement/?hl=headlights "The bulb that he used is Flosser Head Light Fog bulb 9003/hb2/h4 . They are 145 watt high beam/100 watts low beam halogen bulbs." Can that bulb be legal? It looks like it should be as some cars are manufactured with those bulbs. Also interested in thoughts on LED conversions like this EBay item number 122105974423 Thanks, s Quote Link to comment Share on other sites More sharing options...
stangeba Posted January 20, 2017 Share Posted January 20, 2017 Many (many) years ago I switched from the standard OEM headlights to new modern halogen bulbs! It helped. One of the easiest upgrades I have ever done! :-) Bruce Quote Link to comment Share on other sites More sharing options...
MC1970U Posted January 20, 2017 Author Share Posted January 20, 2017 Bruce, Like I said I have halogens in there right now but there pretty old and I don't know what wattage they are. Did you have to run relays? When I changed over to some pretty standard halogens sealed beams on my 83 El Camino I had to use relays as the slight extra current draw was reaping havoc with my headlight switch. When you say "bulbs" do you mean you converted to H4 headlight housing and used H4 type bulbs? Thanks, s Quote Link to comment Share on other sites More sharing options...
monte70car Posted January 20, 2017 Share Posted January 20, 2017 Years ago I changed out the head lights in my 70. I went with a halogens pair with a flat lens from Summit Racing. The headlights aren't used on the car but if they are it lights up the area pretty good. A few years back I brought a set for my 72 went to OPGI and got a set that takes a replacement H4 bulb and as a light that can be used either as a day time running light or as a turn signal. Quote Link to comment Share on other sites More sharing options...
Mike Brichta Posted January 20, 2017 Share Posted January 20, 2017 My suggestion to anyone trying to make headlights or any other electrical items (dash lights, blower motor, turn signals, spark, etc.) work brighter and better would be to upgrade to a 1 wire (105 amp) alternator instead of the stock generator/voltage regulator setup. This single upgrade will instantly greatly improve all electrical components in the car. I've done it on all of my cars and then you can simply buy halogen headlights from Rock Auto for around $10/each. Good luck on whatever you decide!! Quote Link to comment Share on other sites More sharing options...
stangeba Posted January 20, 2017 Share Posted January 20, 2017 Mine are seal-beam halogen type. They look stock. I still have the stock 35 AMP alt and at idle they do dim some. Bruce Quote Link to comment Share on other sites More sharing options...
420ponies Posted January 21, 2017 Share Posted January 21, 2017 I agree on the upgrade to 105 amp alternator. with a set of Halogens is is the perfect solution. I'm running this in mine and liking it ! Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted January 21, 2017 Share Posted January 21, 2017 I believe the best upgrade is to a complete engineered LED headlight, not a LED stick bulb stuck into an aftermarket halogen housing. I want them. Costly though, like $450 a pair for the JW Speaker version. Genssi LED offers the same thing for about $260 a pair. http://www.jwspeaker.com/products/led-headlights-model-8700-evolution-2/ http://www.genssiled.com/product-category/bright-led-headlamps/ The truck-lite at the bottom is the same as the Wagner 6024LED Quote Link to comment Share on other sites More sharing options...
72Ragtop Posted February 2, 2017 Share Posted February 2, 2017 1st thing....with car running, check Voltage at battery that at Lo and then Hi headlite wire connectors. More than likely, depending wire & switch age you'll see a 3 to 5 voltage drop at the headlites. Add relays. Quote Link to comment Share on other sites More sharing options...
MC1970U Posted February 10, 2017 Author Share Posted February 10, 2017 Lots of great info. I was happy with the improvement when I upgraded the headlights to halogen on my Elky. I think I will do the same on the MC, use relays and consider the alternator upgrade. Thanks again everyone, s Quote Link to comment Share on other sites More sharing options...
