Sign in to follow this
Will
Rear Control Arm Boxing
Replacing all the bushings out back and want to box the lower arms in to add some strength and can't afford aftermarket arms Anyone buy plates to weld in? If so where did you get them and were you happy? I've found some for chevelle, I assume these will fit mine as well?
Share this post
I used the aftermarket plates for one I did but had to cut a piece out to shorten them to make it work, the next time I just got some steel flat bar and round steel pipe the same as the bolt size and cut it all to fit, welded the round pipe to where the bolts go through and the flat steel on the bottom.
Leo
Share this post
Create an account
Register a new account
Sign in
Sign In Now
