Will Posted January 21, 2017 Share Posted January 21, 2017 Replacing all the bushings out back and want to box the lower arms in to add some strength and can't afford aftermarket arms Anyone buy plates to weld in? If so where did you get them and were you happy? I've found some for chevelle, I assume these will fit mine as well? Quote Link to comment Share on other sites More sharing options...
monte70car Posted January 21, 2017 Share Posted January 21, 2017 Will the plates for a Chevelle will work as its the same arms. Quote Link to comment Share on other sites More sharing options...
70bowtie Posted January 22, 2017 Share Posted January 22, 2017 I used the aftermarket plates for one I did but had to cut a piece out to shorten them to make it work, the next time I just got some steel flat bar and round steel pipe the same as the bolt size and cut it all to fit, welded the round pipe to where the bolts go through and the flat steel on the bottom. Leo Quote Link to comment Share on other sites More sharing options...
Will Posted January 31, 2017 Author Share Posted January 31, 2017 Thanks for the input guys Quote Link to comment Share on other sites More sharing options...
