Deni2nd Posted January 29, 2017 Share Posted January 29, 2017 Axle casting number N 1248321 ANYONE? Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted January 29, 2017 Share Posted January 29, 2017 What is the code on the tube on the passenger side? Quote Link to comment Share on other sites More sharing options...
Rock Posted January 29, 2017 Share Posted January 29, 2017 http://www.firstgenmc.com/tech/rearaxledecoding.shtml Quote Link to comment Share on other sites More sharing options...
Deni2nd Posted January 29, 2017 Author Share Posted January 29, 2017 CC 035 1 Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted January 30, 2017 Share Posted January 30, 2017 What year car is it supposed to be from? A CCW coded rear was use in 1970. It was a 3.31:1 posi rear end. I see no code that is just CC for a 70-72 Monte. I see a CC code for a 1973, 74 and 75 Monte Carlo which is a 2.73:1 posi rear end. Quote Link to comment Share on other sites More sharing options...
Deni2nd Posted February 4, 2017 Author Share Posted February 4, 2017 That's the reason for the question I don't know what year or for that matter what car it came from When I purchased my car I got lots of different parts this rear being one of them. Looking to identify it so maybe I can sell it The spring perch is directly over the axle unlike a Monte where the springs perch is mounted forward. The shocks on this rear also go in front of the axle as opposed to the rear of the axle like on a Monte Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted February 4, 2017 Share Posted February 4, 2017 I see a CC code for a 1973, 74 and 75 Monte Carlo which is a 2.73:1 posi rear end. The code you posted was CC 035 1. This code should be made up of 8 digits if it is a 73 or 74 rear end. It will be 7 digits if it is a 75 rear end. The 8th digit for a 73 or 74 rear end tells you the posi traction source. If there is no letter after the shift it was built on, or a dash it is not a posi. If there is a E it is an Eaton posi, if there is a G it is a /chevrolet gear and axle posi, if it has a O it is an Oldsmobile posi and if it has a W it is a Warner Motive posi. You only posted 6 digits. From what you posted I get, CC 035 1 ? Feb. 4th First shift CC is a code that was used for 73,74,75 Monte Carlo as a 2.73:1 posi. Looks to me that you are missing one more letter in the area by the CC and possibly one more after the shift. Posting pictures always helps a lot. If the code is really CC, then now we need a letter for the plant it came from. It will be the third letter in the sequence. Otherwise we need a letter before the CC. 1 Quote Link to comment Share on other sites More sharing options...
70bowtie Posted February 5, 2017 Share Posted February 5, 2017 I agree with Dan this looks like it's from a 73-77 GM A-body. You could probably go to this site as he deals in rear ends might be able to answer your question. http://forum.jdrace.com/viewforum.php?f=16 Leo Quote Link to comment Share on other sites More sharing options...
riverdogs00 Posted February 16, 2017 Share Posted February 16, 2017 I'm assuming the 3 letter code should match that on the engine as well? for example, if my 454 has CRN, should the axle match? Quote Link to comment Share on other sites More sharing options...
MCfan Posted February 16, 2017 Share Posted February 16, 2017 I'm assuming the 3 letter code should match that on the engine as well? for example, if my 454 has CRN, should the axle match? Mike, I've never heard that there is a direct relationship between the engine code and the axle code, but there may be one. In any case, they don't "match" on my '70. The engine code is CKR (402/4 LS3 330 hp Manual transmission) but the axle code is CCF (3.31) both of which agree with the RPOs listed on the Build Sheet.. Quote Link to comment Share on other sites More sharing options...
John S Posted February 16, 2017 Share Posted February 16, 2017 I believe 1970 was the only year 3 letters were used for axle ID. My 1970 eng is CNJ 300/350 manual transmission, axle code CCF 3.31 Quote Link to comment Share on other sites More sharing options...
