V8Freak Posted March 19, 2017 Share Posted March 19, 2017 So I do not know where to find the particular seal/guide. One screws too the body on the outside of the window and one clip to the inside. As the rear glass rolls the back runs along these and they seem to keep the window from rattling or moving around and sort of act as a guide. I managed to make outer ones out of wether stripping from the bottom doors of a 06 f150 bit the immersive with the clips I'm having trouble finding. Anyone help? Link to comment Share on other sites More sharing options...
V8Freak Posted March 19, 2017 Author Share Posted March 19, 2017 Found it in another post! Link to comment Share on other sites More sharing options...
genominelli Posted July 1, 2017 Share Posted July 1, 2017 Hi, I am in the same bind, need both the inners and the outers, haven't been able to find these anywhere. Hope we are talking about the same seals, they run vertical at he rear of the quarter glass. Any Suggestions? Link to comment Share on other sites More sharing options...
willie Posted July 2, 2017 Share Posted July 2, 2017 I got mine from Leo, he is listed in the parts section above. Great guy and has everything you need. Link to comment Share on other sites More sharing options...
V8Freak Posted August 16, 2017 Author Share Posted August 16, 2017 They don't make the outers so I took the rocker moulding from a mid 2000's f150 it's perfectly shaped, trimmed to proper length and took a piece of steel to reinforce where you screw it. It's shaped like a v, honestly it worked amazing (From Rob Peters: Matt was having trouble loading the pictures so he emailed them to me and I am loading here for him. Thanks to Matt for this tip. Just a note, when you open each of the pictures look at the bottom o the picture for a brief description of each picture.) Link to comment Share on other sites More sharing options...
Rob Peters Posted August 16, 2017 Share Posted August 16, 2017 They don't make the outters so I took the rocker moulding from a mid 2000's f150 it's perfectly shaped, trimmed to proper length and took a pice of steel to reinforce where you screw it. It's shaped like a v, honestly it worked amazing Do you have any pictures of where on the F150 the piece comes from an early your newly made piece converted to fit? rob Link to comment Share on other sites More sharing options...
V8Freak Posted August 16, 2017 Author Share Posted August 16, 2017 I can't post pics on here but if you give me your email we have a few trucks here I can send you a pic of the piece and location on the truck, you just trim it to length so it butts to the top and goes down just below quarter window Link to comment Share on other sites More sharing options...
V8Freak Posted August 16, 2017 Author Share Posted August 16, 2017 The width is perfect you literally only need to trim for length and find a thin metal strip to put inside the v of the rubber so the screws don't pull through the rubber and also so the whole length sits somewhat flat against the car. Link to comment Share on other sites More sharing options...
V8Freak Posted August 16, 2017 Author Share Posted August 16, 2017 The inside pieces they do make new I got mine on summit Link to comment Share on other sites More sharing options...
Rob Peters Posted August 16, 2017 Share Posted August 16, 2017 Email the pictures to me at rob29ford@aol.come and I will post them for you. rob Link to comment Share on other sites More sharing options...
V8Freak Posted August 16, 2017 Author Share Posted August 16, 2017 Will do Link to comment Share on other sites More sharing options...
V8Freak Posted August 16, 2017 Author Share Posted August 16, 2017 They really need to make uploading pictures easier on here Link to comment Share on other sites More sharing options...
Rob Peters Posted August 16, 2017 Share Posted August 16, 2017 When I do it they will be thumbnails that expand when clicked on. rob Link to comment Share on other sites More sharing options...
V8Freak Posted August 16, 2017 Author Share Posted August 16, 2017 Sent Link to comment Share on other sites More sharing options...
Rob Peters Posted August 16, 2017 Share Posted August 16, 2017 I have added Matt's pictures to his earlier post. Thanks to Matt for this tip because this is a part many here have looked for and/or attempted to reproduce.. rob Link to comment Share on other sites More sharing options...
