A/C POA Valve
Seems like each time I want to use the A/C. something in the system takes a dump!  So this time the POA Valve quit letting 134A propellant pass thru the POA Valve and into the cabin.  A/C guy said POA Valve needs replaced.  I ended up getting the UPGRADE KIT as I could not locate a OEM POA Valve at that time.  I have since seen a few that pretty much are vague in description/applications but all look alike.  When advertised GM cars from 1965 to 1975 in the description tells me that is only part of the story.
So anyone here versed in our OEM A/C cars that can shed any light on what I need to look for for a replacement POA Valve?
Thanx in advance for your input. ;)
Doug
Hey DOug, I've been told these guys  are the ones to trust even tho I've never used them........ https://originalair.com/about-poa-valves
Thanx for the info Murphy.  I will certainly have a conversation with them and determine which Valve it is and if my Valve can be refurbished.
Doug
