MC-71 Posted June 22, 2017 Share Posted June 22, 2017 I want to change my old steel fuel line with neoprene with flex stainless from the fuel tank to the fuel pump. Has anyone done this and what kind of flex hose did you use? Carl Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted June 23, 2017 Share Posted June 23, 2017 I wouldn't stainless braided line is a pain and expensive, your factory steel line...if in good condition...is the best way to good unless you NEED! a larger line, and if you have the 3/8" steel line...I highly doubt you need anything larger unless you're pushing close to 550 or more horse power Quote Link to comment Share on other sites More sharing options...
GatorDog72 Posted June 23, 2017 Share Posted June 23, 2017 I used earls ultra flex line and fittings. It doesn't really matter what brand you use, as long as you get the fittings from the same company who makes the hose. Sam is right, it was a massive pain in the butt to do mine and it's really not worth it unless you NEED the larger diameter line. Quote Link to comment Share on other sites More sharing options...
MC-71 Posted June 24, 2017 Author Share Posted June 24, 2017 Okay I will take the advice and run the steel line that I have. Can I cut it in half and flare both ends and install a coupling to make it back up? Thanks Carl Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted June 24, 2017 Share Posted June 24, 2017 Okay I will take the advice and run the steel line that I have. Can I cut it in half and flare both ends and install a coupling to make it back up? Thanks Carl that will be fine I ran a -10 (5/8") stainless braided (nylon inner) pricey and a pain, it was when I had the 12:1 468 in it Quote Link to comment Share on other sites More sharing options...
