Message Board
2018 Western Meet
[clock1]
2018 Eastern Meet
[clock2]
Frame cleanup
  • Please log in to reply
4 replies to this topic
#1 MonteMack
MonteMack
    Advanced Member
  • Members
  • 80 posts
  • LocationVancouver Bc
  • Legal Name:Mackenzie Pearson
  • Occupation:Student
Posted 31 August 2017 - 02:52 PM
In the midst of replacing all my front end parts etc and was wondering what I could do to cleanup the frame, sand? Grind? Do i gotta pull the body off to get better access or can I just do it as is?
Heres a few pics : http://imgur.com/a/6PwKy
Any feedback is appreciated, cheers.
#2 stangeba
stangeba
    Original Owner
  • Members
  • 4,715 posts
  • LocationShelby Township, Michigan
  • Legal Name:Bruce Stange
  • Occupation:Retired from E. I. DuPont Automotive Finishes still working at Langdon's Stovebolt Engine Parts Company.
Posted 31 August 2017 - 05:10 PM
Back in 1983 All I used was a wire wheel on a drill or just the wire brush. It still looks very nice after 34 years. (see attached before and after) I did the firewall and ft section of the frame when the engine and trans was out. I later did the rear when the rear axle was out. No way I could do that stuff now, I'm too old.
I think I used DuPont black Corlar primer and a lower gloss black IMRON.
Attached File  83_06_06.jpg   85.75KB   1 downloads
Attached File  83_06_12.jpg   111.56KB   0 downloads
Posted Image
Original Owner since May 14 1971
#3 7tonemonte
7tonemonte
    Its Sooooo GREEN!! FGMCC Treasurer
  • Moderators
  • 15,243 posts
  • LocationChester County Pa.
  • Legal Name:Tony
  • Occupation:Auto painter
Posted 01 September 2017 - 03:40 AM
Depends on how carried away you want to get. I wire brushed mine, and brushed on rustoleum. Still holding up fine after 13 years.
You could go all the way to sandblast and powder coating. I can tell you that mine is in really good shape after quite a lot of driving
Green Tony!
Posted Image
Posted Image
Ill paint your toenails if you can stand still long enough
Click here to see my Monte build so far
---RIP Robyn Lance---
#4 TAG429
TAG429
    Advanced Member
  • Members
  • 63 posts
  • LocationDavisburg, MI
  • Legal Name:Timothy Gallagher
  • Occupation:IT Project Manager
Posted 01 September 2017 - 04:42 AM
I just recently did my frame with the engine in the care during my brake overhaul.  I pulled the front fender wells since they need to be replace so it provided excellent access.  I taped up the oil pan and anything else I did not want to get paint on.  Then I used KBS coatings satin using different size foam brushes..  I even went as far as painting the underside and outside of the frame rails front to back.
IT came out real nice and cleaned up the looks a lot.  My care was fairly clean to begin with therefore I just cleaned the heck out of it with degreaser, simple green and used acetone just prior to painting.
#5 71MonteCarloMD
71MonteCarloMD
    Gold Member
  • Members
  • 2,134 posts
  • LocationFrederick, MD
  • Legal Name:Rick Baker
  • Occupation:IT Projects Director
Posted 01 September 2017 - 11:46 AM
I used wire wheel then applied POR15 on front end part while I had my front end disassembled with engine still in.
Home Page
Message Forum
Members' Montes|Meet Photos
