Message Board
2018 Western Meet
[clock1]
2018 Eastern Meet
[clock2]
Stock Front Sway bar VS. Larger aftermarket Unit
  • Please log in to reply
15 replies to this topic
#1 NWmonte71
NWmonte71
    Advanced Member
  • Members
  • 91 posts
  • LocationPoulsbo, WA
  • Legal Name:Chris Harris
  • Occupation:DON
Posted 12 September 2017 - 06:05 PM
Just like the title says, what is the advantage of a larger aftermarket front sway bar versus the stock unit? More control, less roll, smoother steering?  I plan to lower my car and install larger wheels over the Winter. I would assume installing a larger diameter front sway bar would help? I see several companies selling these in different diameters, Hotchkis, Addco, UMI, etc. I would appreciate if someone could explain the advantages or disadvantages of an aftermarket unit.
sml_gallery_5838_288_247210.jpg1971 Monte Carlo, #'s matching 350cid with TH350, Factory "Lime Green" with original "Antique White" painted top.
#2 72Ragtop
72Ragtop
    Member
  • Members
  • 233 posts
  • LocationLoveland, Colorado
  • Legal Name:David C. Winters
  • Occupation:Abused taxpayer
Posted 13 September 2017 - 08:06 AM
Given you have good radial tyres, and not 40 year old bias-plys, a set of larger front AND rear anti-roll bars (w/ poly-bushings!) is the most "cost-effective" modification you can do to any car of this age to improve the handling and the "feeling". DCWinters
#3 Rob Peters
Rob Peters
    Retired Vice President FGMCC
  • Administrators
  • 15,345 posts
  • LocationPittsburgh, Pa. USA
  • Legal Name:Rob Peters
  • Occupation:Retired Senior Field Engineer Ortho-Clinical Diagnostics
Posted 13 September 2017 - 08:17 AM
I agree with Davie with one exception and that is the Poly bushings. A lot of people here have been very unhappy with the poly because most of them start to squeak. The rubber are fine and also last a long time.
The heavier bar will help reduce body roll/sway and improve handling.
To access my website click the link below
My Two Girls
http://www.cardomain...robsmodelamonte
Go Car or Show Car, it doesn't matter, you are welcome here
#4 Shnalla
Shnalla
    Keep the Rock rolling !
  • Members
  • 252 posts
  • LocationLyon, France.
  • Legal Name:Romain Scheibert
  • Occupation:Art Director
Posted 13 September 2017 - 12:35 PM
Does poly bushings squeak even with regular lubrication?
Romain
Posted Image
Work Hard, Make Money, Fix your Car !
#5 Leghome
Leghome
    Maytag "Danged Agitator"
  • Members
  • 4,961 posts
  • Location35 mi NE of INDY
  • Legal Name:Larry E Gilbert
  • Occupation:Retired maybe
Posted 13 September 2017 - 03:21 PM
Yes.
http://www.firstgenm...-monte-trailer/
Larry E Gilbert
Markleville IN
"IF'n I had know retirement was this good I'd have done it a lot sooner"
#6 502ci
502ci
    MODERATOR in the 11's
  • Moderators
  • 15,371 posts
  • LocationRichfield, Ohio
  • Legal Name:Bill
  • Occupation:Union Electrician / Local 38/Commercial, Industrial
Posted 13 September 2017 - 03:36 PM
Never noticed mine squeaking...then again my car is loud.
Get a hollow one to save weight. I do got to say if you do your whole car with rubber bushings the sway bar is one place to use poly, the end links and the frame mounts for the front sway bar will give you a "quick" road feel when turning hard, you won't have that soft delayed feel. I have had both and originally when I put poly just on my end links on my "stock" bar there was a noticeable difference.
Bill
MolĂ´n Labe
11.80's at 114 mph, 0-60 in 3.34 sec.____
Click here to see my never ending project
__________Click here to hear it__________
#7 stangeba
stangeba
    Original Owner
  • Members
  • 4,715 posts
  • LocationShelby Township, Michigan
  • Legal Name:Bruce Stange
  • Occupation:Retired from E. I. DuPont Automotive Finishes still working at Langdon's Stovebolt Engine Parts Company.
Posted 13 September 2017 - 06:27 PM
Squeak,  Squeak, Squeak, Squeak, Squeak, Squeak, Squeak, Squeak
I replaced the 7/8" with a 1-1/8" ft bar and added a rear bar, all Chevrolet parts, years ago.
Only part I wish I had not done, was the poly bushings, they were SOOOO much work.
To be honest, I think I remember an improvement but..........
Bruce
Posted Image
Original Owner since May 14 1971
#8 NWmonte71
NWmonte71
    Advanced Member
  • Members
  • 91 posts
  • Occupation:DON
Posted 13 September 2017 - 07:44 PM
I appreciate all the replies up to this point. It seems installing a larger sway bar would benefit me up front. I like a real crisp handling/driving experience, so perhaps using the poly bushings would be beneficial. Somewhere online I read an article where one person said you can save some massive money by buying an OEM 70-81 Camaro sway bar. I guess these came in a large diameter (1-1/8") and fit a chevelle..........which means they would fit a monte carlo. Anyone heard of this?
#9 Shnalla
Shnalla
  • Members
  • 252 posts
Posted 14 September 2017 - 01:59 AM
Just to clarify ; rear swaybar exists from factory on Montes or is a Chevelle option?
  • Montemedic likes this
Romain
Posted Image
#10 71MonteCarloMD
71MonteCarloMD
    Gold Member
  • Members
  • 2,134 posts
  • LocationFrederick, MD
  • Legal Name:Rick Baker
  • Occupation:IT Projects Director
Posted 14 September 2017 - 10:46 AM
Rear swaybar was available as an option from factory as I have it on my 71.
  • Shnalla likes this
#11 Rob Peters
Rob Peters
  • Administrators
  • 15,345 posts
Posted 14 September 2017 - 11:42 AM
Rear sway bar was part of the SS suspension package but an option on others.
My Two Girls
#12 MCfan
MCfan
    Gold Member
  • Members
  • 2,628 posts
  • LocationPunta Gorda, FL (winter); Crosslake, MN (summer)
  • Legal Name:Dennis Bengtson
  • Occupation:Retired Management Consultant
Posted 14 September 2017 - 09:54 PM
The front stabilizer shaft (GM's terminology) on every '70 SS, '71 SS and '72 Custom (and every other Monte with the F41 Performance Suspension option) is 1 1/8" diameter instead of the standard 15/16" diameter.  While the Factory Assembly Manual only shows the rear stabilizer shaft, shims, bolts and boxed control arms for RPO F41 (pages 548 & 549), the larger front shaft is clearly called out as "not illustrated" along with different front shocks and rear springs. Unfortunately, instead of giving a Part Number for the 1 1/8" shaft, the Assembly Manual simply refers the reader to the Bill of Material which apparently came with RPO F41.
Be aware if you choose the factory 1 1/8" front stabilizer, you will also need the larger bushings for that diameter and they are not so easy to find.  More than one parts source tried to sell me the standard bushings when I rebuilt the front suspension on my '70 SS three years ago.  I know Leo can get them if no one else stocks them.  Good luck.
Dennis
1970 matching #'s 402/M20 4-speed/3.31 12-bolt Posi                1970 SS454/TH400/2.56 12-bolt Posi
Punta Gorda, FL        Crosslake, MN
#13 NWmonte71
NWmonte71
    Advanced Member
  • Members
  • 91 posts
  • Occupation:DON
Posted 17 September 2017 - 03:17 PM
Good info!  Yeah, I found 1-1/8" new sway bar through OPG for right around $100. I plan to buy polyurethane end links and frame bushings. I realize that squeaking is an issue, but I also want that tight direct feeling with the steering. My 71 already has a rear sway bar installed. It definitely looks like a previous owner added it on, the hardware looks fairly shiny & new. I checked my front sway bar on the 71, it measures out to 1" diameter.......... is this an available size?
#14 waupachino
waupachino
    Member
  • Members
  • 264 posts
  • LocationSt. Louis
  • Occupation:HR
Posted 29 September 2017 - 12:53 PM
A 1 1/4 inch bar off of a Trans Am works great also, but the best addition I've ever made to mine in regards of handling is an HR PartsNStuff rear Anit-Roll Bar.  I know these things were mainly produced for Drag Racing and increased traction, but I can't begin to tell you how much it's improved the handling and feel of my Monte Carlo.  Even with slicks in the rear and skinnies up front, it feels like it's on rails.  Before the bar it felt very loose.
#15 NWmonte71
NWmonte71
    Advanced Member
  • Members
  • 91 posts
  • Occupation:DON
Posted 29 September 2017 - 06:09 PM
Will a Trans Am 1-1/4" sway bar fit without any clearance issues/rubbing?
#16 waupachino
waupachino
    Member
  • Members
  • 264 posts
  • LocationSt. Louis
  • Occupation:HR
Posted 04 October 2017 - 02:32 PM
Yes, no issues at all.
Home Page
Message Forum
Members' Montes|Meet Photos
