bettare Posted September 24, 2017 Share Posted September 24, 2017 Quick question ,does the back windows on a 71 have springs on the door cranks? Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted September 24, 2017 Share Posted September 24, 2017 I hate Trick Questions. You must be talking about a Chevelle because we all know Monte'so didn't have door handles. Just kidding Guy, if I am not mistaken, all of the Window cranks, front and rear, had the panel springs. That said...... was the spring used with the electric window buttons????...again just kidding, we all know the answer to that. rob Quote Link to comment Share on other sites More sharing options...
bettare Posted September 24, 2017 Author Share Posted September 24, 2017 Thanks for the info on the rear window crank spring. When adjusting the window I noticed they were missing in the rear. Probably when I had the monte restored several years ago they did not replace them. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted September 25, 2017 Share Posted September 25, 2017 Guy, I am trying to remember the proper placement of that spring.  I can't remember if it goes between the door panel and the plastic protector plate or between the plastic proctor plate and the crank.  I do know part of it's job is to protect the door panel  from the spinning of the window crank against the door panel. rob Quote Link to comment Share on other sites More sharing options...
overdrive Posted September 25, 2017 Share Posted September 25, 2017 Spring, trim panel, plastic protector, crank. Â Dan Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted October 12, 2017 Share Posted October 12, 2017 Which way do we put spring in. larger or smaller towards door? Quote Link to comment Share on other sites More sharing options...
Leghome Posted October 12, 2017 Share Posted October 12, 2017 Small end towards door and between the door panel and the door. Quote Link to comment Share on other sites More sharing options...
