Mike Brichta Posted October 4, 2017 Share Posted October 4, 2017 I now see that the steering columns are different between a 4 speed car and an automatic car. The tab at the bottom where the lock-out mechanism connects is different in length and shape. That leads to 2 questions: 1) Can the automatic trans column be used with a 4 speed trans and have the lock-out mechanism work correctly, or does the arm have to be changed? 2) How hard is it to change the 2 different arms and can it be done while the column is still in the car? Thanks!!Mike Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted October 5, 2017 Share Posted October 5, 2017 I would say you will need to re shape the automatic arm to look like the 4 speed arm. Others have made this modification. I would remove the column from the car to do the modification. Quote Link to comment Share on other sites More sharing options...
