X or H crossover pipe
beater72
What are the big block guys running for a crossover pipe,if any? 454,basically stock with long tube headers? I know on my 71 Maverick I'm running duals with an x pipe...
If you are not heavily modified and don't need every ounce of power I would not install any type of cross over...in my opinion you loose that true dual exhaust sound when you install one.
If you do use an X type you will have extra bends in your pipes to join them together and then more to separate them to mufflers...an H type is just a cross over joining the two pipe runs together. Now you would think less bends equates to more power but everything I have read in the past pointed to an X type making more power.
I myself went with an exhaust diameter so large it did not matter to join the two together so I stopped researching it  :D
