monte70car Posted November 5, 2017 Share Posted November 5, 2017 What fitting is everyone running for their power brakes? I got a stock power brake fitting with two other vacuum sources but it doesn’t work with the intake I’m running. Quote Link to comment Share on other sites More sharing options...
badddoin Posted November 5, 2017 Share Posted November 5, 2017 I wasn't able to get a fitting to work anywhere on my intake, without interfering with the carburetor. I just ran a short piece of rubber line from the base of the carburetor to a "T", one side goes to the booster, the other to the PCV. Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted November 13, 2017 Share Posted November 13, 2017 I installed a vacuum pump for the brakes. Got it from summit. I installed it in the left front corner of the engine compartment. Bolted to the fenderwell, tucked under the fender and the windshield washer tank. Out of sight unless you look for it. It has worked flawlessly and with the car running, you can’t hear it. Quote Link to comment Share on other sites More sharing options...
