Message Board
2018 Western Meet
[clock1]
2018 Eastern Meet
[clock2]
One wheel has tons of negative camber suddenly
  • Please log in to reply
11 replies to this topic
#1 VT Monte
VT Monte
    Junior Member
  • Members
  • 12 posts
  • LocationNorth Carolina
  • Legal Name:Ken
  • Occupation:Software
Posted 13 November 2017 - 08:46 AM
Went out driving the other day and noticed the handling got a little squirrelly under braking and turns. Took a look when I got home and noticed the passenger side wheel has tons of negative camber now, almost an inch and a half off neutral/vertical. Driver side is still neutral.
My first inclination was to adjust it back to vertical with some shims on the control arm but because only one wheel went weird on me like this what else could have gone wrong/broken? If possible I'd like to replace the parts that need replacing before handing it over for a professional alignment. Everything is 1970 stock currently except the coil springs.
#2 MCfan
MCfan
    Gold Member
  • Members
  • 2,755 posts
  • LocationPunta Gorda, FL (winter); Crosslake, MN (summer)
  • Legal Name:Dennis Bengtson
  • Occupation:Retired Management Consultant
Posted 13 November 2017 - 09:37 AM
Ken,
With a sudden shift in camber of that amount, your Monte has undoubtedly experienced complete failure of one or more suspension components.  It could be any of the upper or lower control arm bushings or ball joints, the upper control arm mounting bar or some combination of these.  I suggest you not drive the car again until you figure out and replace whatever has failed.
If you jack the front passenger side up enough to get the wheel off the ground and put it on a jack stand with rear wheels blocked, you might be able to wobble the front wheel enough while observing the suspension components to see where there is excessive play.  I've completely rebuilt the front suspension on both of my '70s and found some normal wear but nothing like what you are describing.
Dennis
1970 matching #'s 402/M20 4-speed/3.31 12-bolt Posi                1970 SS454/TH400/2.56 12-bolt Posi
Punta Gorda, FL        Crosslake, MN
#3 VT Monte
VT Monte
    Junior Member
  • Members
  • 12 posts
  • Legal Name:Ken
Posted 13 November 2017 - 09:48 AM
I figured as much. Thanks. Sounds like a good excuse to start upgrading during the winter months.
#4 Murphy
Murphy
    Silver Member
  • Members
  • 1,535 posts
  • LocationChandler, AZ
  • Occupation:Service Mgr.
Posted 13 November 2017 - 03:46 PM
An inch&half from vertical is a lot! Don't drive it, I'll bet it's a wheel bearing. Jack her up and see how much slop you have in the wheel...good luck!
I started out with Nothing........I still have most of it!
1971 SBC355, Muncie M20 4-Speed
#5 cny first gen 71
cny first gen 71
    Platinum Member
  • Members
  • 4,791 posts
  • LocationLiverpool N.Y. USA
  • Legal Name:Steve Lavoie
  • Occupation:supervisor
Posted 13 November 2017 - 04:06 PM
Check the shims to see if any have fallen out, I had this happen on mine. Bent broken or worn is about the only reason a car will go out of alignment and to happen all of a sudden like that is strange. Look it over good as the others have said, shouldn't be to hard to find being that far off.
There is no such thing as strangers, only friends we have yet to meet.
Posted Image
#6 VT Monte
VT Monte
    Junior Member
  • Members
  • 12 posts
  • Legal Name:Ken
Posted 13 November 2017 - 06:37 PM
Thanks, everyone. I'll let you know what I find when I get the time to look at her.
#7 Rob Peters
Rob Peters
    Retired Vice President FGMCC
  • Administrators
  • 15,759 posts
  • LocationPittsburgh, Pa. USA
  • Legal Name:Rob Peters
  • Occupation:Retired Senior Field Engineer Ortho-Clinical Diagnostics
Posted 13 November 2017 - 07:03 PM
Yes, that much out is a lot.  Like the others have said something has suddenly failed.  If the upper control  bolts came loose I agree with Steve that the shims could have fallen out.  A complete failure of one of the control arm bushings could have also happened since almost 50 year old rubber bushings of an original suspension (you did say it was all original except the springs) failing would not surprise me.
It will be interesting to hear the final solution.
To access my website click the link below
My Two Girls
http://www.cardomain...robsmodelamonte
Go Car or Show Car, it doesn't matter, you are welcome here
#8 VT Monte
VT Monte
    Junior Member
  • Members
  • 12 posts
  • Legal Name:Ken
Posted 21 November 2017 - 08:53 AM
Looks like Steve wins the 10 fake internet points, he called it correctly. Found time to get in there and discovered the nuts had loosened quite a bit off the bolts and whatever shims were in there fell out. Glad I discovered it before they came out completely. Yikes.
Other side looks like it lost some of it's shims as well. 3 on one bolt, none on the other. Time to pick up some shims. Thanks everyone! Luckily the fix was cheap this time.
Picture of the affected control arm from the top here: https://imgur.com/a/kRSqu
  • cny first gen 71 likes this
#9 zmanabba
zmanabba
    Member
  • Members
  • 248 posts
  • LocationSpokane, WA
  • Legal Name:David Grant Ziemer
  • Occupation:Truck driver
Posted 21 November 2017 - 01:11 PM
Check also that the studs weren't damaged by the control arm moving around. If they were make sure and replace it with the correct part. It's knurled to lightly press in to the mounting point. Don't use a bolt like the PO of my 70. If the stud is okay at least put new nuts on it they are locking type like on a rocker arm nut chances are they are worn out and that's why they loosened up. I got mine I think from Year One but any of the restoration suppliers should have the studs and nuts. David
#10 MCfan
MCfan
    Gold Member
  • Members
  • 2,755 posts
Posted 21 November 2017 - 07:33 PM
If the nuts are loose on the other side, you may have a similar problem, but just an unbalanced number or different thickness of shims on the two studs is not necessarily wrong or a problem if it is what your suspension requires to be aligned.
I was shocked to see such a difference on my '70 SS when I rebuilt the front suspension, but when I had it professionally aligned, it ended up with the same shim configuration as when I started the rebuild.
Attached File  P6256035.JPG   145.73KB   0 downloads
Dennis
#11 cny first gen 71
cny first gen 71
    Platinum Member
  • Members
  • 4,791 posts
Posted 21 November 2017 - 07:56 PM
Yes your definitely going to want to get it in a good alignment shop to get it checked.
Posted Image
#12 VT Monte
VT Monte
    Junior Member
  • Members
  • 12 posts
  • Legal Name:Ken
Posted 22 November 2017 - 01:21 PM
Yep, gonna get it drivable and not quite as dangerous then run it over to a good shop.
Home Page
Message Forum
Members' Montes|Meet Photos
