Message Board
2018 Western Meet
[clock1]
2018 Eastern Meet
[clock2]
Fuel Pressure Regulator
  • Please log in to reply
5 replies to this topic
#1 201fireman
201fireman
    Member
  • Members
  • 210 posts
  • LocationAppleton Wisconsin
  • Occupation:Fire Chief
Posted 21 November 2017 - 08:49 PM
I am looking into a fuel pressure regulator and am curious what others are using?  I have a small block with a mechanical pump.  Curious if others are using a return or non-return style? brands? Pressure ranges? Etc.  Any thoughts?
#2 stangeba
stangeba
    Original Owner
  • Members
  • 4,774 posts
  • LocationShelby Township, Michigan
  • Legal Name:Bruce Stange
  • Occupation:Retired from E. I. DuPont Automotive Finishes still working at Langdon's Stovebolt Engine Parts Company.
Posted 22 November 2017 - 12:02 PM
The factory never used them so I question why anyone would need one on a stock pump / carb system.
My brother in-law, a retired Chevrolet powertrain engineer, very strongly advises NOT to use one.
What we all need, with today's fuel, is a good fuel filter, not the plastic see through lawnmower type I see all the time.
IMO
Bruce
Posted Image
Original Owner since May 14 1971
#3 MC1of80
MC1of80
    Member
  • Members
  • 153 posts
  • LocationStaten Island, New York
  • Legal Name:Thomas Ferrante
  • Occupation:Bus Mechanic NYCTA
Posted 22 November 2017 - 04:25 PM
There should be no need for a pressure regulator with a mechanical pump unless it is a monster. I have a holley 170gph mechanical pump on my monte and do not have or need a regulator. If you are going to switch to an electric pump then a name brand regulator would be best. As far as return line or not. That’s up to you. Either that being said, if you are doing a lot of street driving I would go with a return line to beep the fuel as cool as possible and so the pump won’t “dead head” or have the fuel cavitate. If race only, no return line is necessary. If changing to fuel injection, a return line is recommended. Hope this helps.
#4 bigtankjones
bigtankjones
    1st gen Monte Lover
  • Members
  • 3,219 posts
  • LocationBay City, Mi
  • Legal Name:Tony Jones
  • Occupation:skilled trades(uaw machine repair)
Posted 23 November 2017 - 06:03 PM
I only use a fuel pressure regulator on my electric fuel pump. That way I can maintain 7 psi to my 4160 Holley 750.
It's a Monte thing. You just wouldn't understand.
1970 Monte Carlo, Big Block 454.
#5 MAQ's72
MAQ's72
    Advanced Member
  • Members
  • 55 posts
  • LocationN.P.R. FL.
  • Legal Name:Mike Quinones
  • Occupation:Production Manager
Posted 24 January 2018 - 08:25 PM
Not to bring up or highjack an older thread but what is the setup you have in your Monte bigtankjones ?? as far as your electric fuel pump and reg. set up is it a return line type? Looking to go to electric fuel pump set up in mine but trying to find a good dependable inline unit that's not too super loud. Can't swing $600 plus on an in tank set up.this time around.
My 1972... work in progress
#6 MAQ's72
MAQ's72
    Advanced Member
  • Members
  • 55 posts
Posted 27 January 2018 - 10:55 PM
Thanks for the Impute in PM....
Thanks or the Impute, I definitely need to go with an electric.
Today I rerouted and replaced my fuel lines away from heat sources as best as possible and installed a fuel reg & gauge and really showed the story.... when the motor started up and was cold I had over 7 psi and took her for a spin and she ran awesome, most power I have felt with the 750 Edelbrock but in 10 minutes time she warm up to full temp and my psi dropped to 3 ... ran totally different... I see I'm starving my carb i believe. The mechanical fuel pump gets extremely hot and I can see the fuel level on the glass fuel filter drop......  thought about replacing the mechanical with a new one but dont think it's worth it with the Florida weather.... I need more dependable fuel pressure....
Home Page
Message Forum
Members' Montes|Meet Photos
