Message Board
2018 Western Meet
[clock1]
2018 Eastern Meet
[clock2]
Radio Hole Ideas
  • Please log in to reply
8 replies to this topic
#1 Katman
Katman
    Bronze Member
  • Members
  • 814 posts
  • LocationPennsylvania
  • Legal Name:Mark Katuszonek
  • Occupation:IT Guy
Posted 12 February 2018 - 08:34 PM
I'm putting my 8 track back in and the holes were cut at some point.  The right side hole is a bit too big so the 8 track wants to dip about a 1/16 of an inch on the right.  I'm using the metal cup inserts and need ideas on how I can fix that right side hole so that the cup sits at the top of the hole.  I thought about cutting out a round piece of material slightly smaller than the hole and using goop to glue it to the back side of the dash.  I'll try to post pictures so you know what I am talking about.  In the third picture which is a bit blurry, you can see that hole is slightly larger.
  • mr7tmonte likes this
The Kat
#2 Blackhawk
Blackhawk
    Advanced Member
  • Members
  • 82 posts
  • LocationCentral MN
  • Legal Name:Cody M
  • Occupation:Engineer
Posted 12 February 2018 - 09:32 PM
I would think that a two-part epoxy would bridge the gap and hold everything in place without any issue.  I've used it to repair the broken mounting studs on newer mirrors, it holds pretty well unless they get hit again by a carwash or somebody hip checking them in a parking lot.
Do you have a support strap from the back of the 8 track to the metal frame of the dash?  That should make the unit move less.
#3 Katman
Katman
    Bronze Member
  • Members
  • 814 posts
  • Occupation:IT Guy
Posted 13 February 2018 - 09:05 AM
The L shaped bracket is attached to the back of the 8-track and that helps but it still wants to slide down to the bottom of the hole.  It doesn't move much but figured it will when the car is back on the road.  Since the dash is out, now would be the time to fix it.  I'm not sure what  a two part epoxy is.  Is that something they sell at NAPA Auto Parts?
The Kat
#4 Blackhawk
Blackhawk
    Advanced Member
  • Members
  • 82 posts
  • Legal Name:Cody M
Posted 13 February 2018 - 09:57 AM
They should have this or something similar at any auto parts store or hardware store:
https://www.jbweld.c...earweld-syringe
Make sure that it works with metal and plastic if those are your two surfaces.
#5 RealRed70
RealRed70
    Junior Member
  • Members
  • 607 posts
  • LocationWisconsin
  • Legal Name:Dan Starr
Posted 13 February 2018 - 11:34 AM
Walmart sells two part epoxy as well. Just sayin.
#6 mr7tmonte
mr7tmonte
    Junior Member
  • Members
  • 2 posts
  • LocationVirginia
  • Legal Name:Gerry Patterson
  • Occupation:Retired
Posted 20 February 2018 - 08:08 AM
Hi Katman,
I have a 1970 Monte Carlo (I am the original owner) and at some point in my youth cut out the cups in the dash to install a more modern radio.  I would now like to install a classic look alike radio with modern features.  Where did you get the replacement cups?
#7 Blackhawk
Blackhawk
    Advanced Member
  • Members
  • 82 posts
  • Legal Name:Cody M
Posted 20 February 2018 - 12:40 PM
Hi Katman,
http://www.chevelles...epair-cups.html
http://www.chevelles...stand-offs.html
There's some information on using Nova radio mounting cups as well, I'll have to take a look at my brother's Nova to see if it would work.
#8 mr7tmonte
mr7tmonte
    Junior Member
  • Members
  • 2 posts
  • LocationVirginia
Posted 20 February 2018 - 05:59 PM
Thank you Blackhawk--great information!  I found a post by Dean on the second link which provided another link to diagrams and procedures for replacing the cups: http://macc.chevelle...dash_repair.pdf
I'm now considering a lower priced temporary fix with a modern radio which fits in the currently configured dash (no cups) and new speakers.  From previous postings, it appears that finding replacement dash speakers that fit (particularly on the driver's side) is a challenge.  I'm considering the 3.5" R-352N Retrofit Speaker or the Kicker 43DSC3504 ( Any suggestions for these or rear speakers which I think would be 6" X 9?"
#9 Katman
Katman
    Bronze Member
  • Members
  • 814 posts
  • Occupation:IT Guy
Posted 11 April 2018 - 07:59 AM
I had cups - did not have to replace them.  One of the holes was slightly enlarged so I used some Permatex Steel Weld to tighten up the fit.  Kept the cup in place while it dried.  It has a nice tight fit now.
The Kat
Home Page
Message Forum
Members' Montes|Meet Photos
