1970mcss Posted March 24, 2018 Share Posted March 24, 2018 Is there any trick to removing the lower door moldings? I see two screws, one on each end but I'm not. Sure how to remove the clips. Quote Link to comment Share on other sites More sharing options...
black07ss Posted March 24, 2018 Share Posted March 24, 2018 Remove the screws then push down on the molding and at the same time pull out at the bottom of the molding works for me Quote Link to comment Share on other sites More sharing options...
Leghome Posted March 24, 2018 Share Posted March 24, 2018 If they are after market be very careful even with Bob,s method (one of the best) they will bend. I have experience inthis 1 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted March 24, 2018 Share Posted March 24, 2018 Paul do you mean the door molding or the rocker panel molding? Quote Link to comment Share on other sites More sharing options...
1970mcss Posted March 24, 2018 Author Share Posted March 24, 2018 The door molding. They don't seem to lay flat to the door. They seem to bow out so I not sure if thats normal or maybe some clips are missing Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted March 25, 2018 Share Posted March 25, 2018 There isn't supposed to be screws holding that on, there plastic clips that pop into the door and molding pops onto them. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted March 25, 2018 Share Posted March 25, 2018 Steve is correct.... No screws in the door moulding, rob Quote Link to comment Share on other sites More sharing options...
overdrive Posted March 25, 2018 Share Posted March 25, 2018 Yes, there are 2 screws. Like he said, they are at each end. The screws are found by opening the door and looking at the door edges. They go into the end clips that slide into the ends of the trim. Â Dan 1 Quote Link to comment Share on other sites More sharing options...
Leghome Posted March 25, 2018 Share Posted March 25, 2018 Dan U be right just looked at my 72 1 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted March 25, 2018 Share Posted March 25, 2018 Oh yea I forgot about them, your right. Must be old timers because I've had them off a couple times. Quote Link to comment Share on other sites More sharing options...
Canuck Posted March 25, 2018 Share Posted March 25, 2018 Yes a screw on each end accessible from inside the door. Then pop it off the plastic clips. Quote Link to comment Share on other sites More sharing options...
