dejh22 Posted June 8, 2018 Share Posted June 8, 2018 Well I couldn't take it any longer. The rear main seal started leaking more so I decided to replace it. Last fall I was convinced it was the oil pan gasket. I wish I would have replaced the rear main at the same time. The seal on the bottom looks to be the problem it is a little long on one side. The seal on the top was flush with the block. I would of thought my guy would of caught this. This was the first time I had him do the short block. I just need to clean everything and wait for the new seals to show up. Quote Link to comment Share on other sites More sharing options...
overdrive Posted June 20, 2018 Share Posted June 20, 2018 Typically, guys install them with each half rotated a little, so the parting lines of the seals aren't flush with the surfaces of the block and the bearing cap. It can be tough to get a great seal. Dan 1 Quote Link to comment Share on other sites More sharing options...
dejh22 Posted June 21, 2018 Author Share Posted June 21, 2018 Typically, guys install them with each half rotated a little, so the parting lines of the seals aren't flush with the surfaces of the block and the bearing cap. It can be tough to get a great seal. Dan I went ahead and just lined them up. I did add just a little rtv. Went back together good and doesn't leak anymore. I now have to figure out why it smokes a little and the oil smells like fuel. I have been in touch with my machinist and he trying to help me figure out what could be going on. Oh plus I noticed the water pump is leaking. Quote Link to comment Share on other sites More sharing options...
