amsterdam84
Finally installing my...
Viking Performance coilover kit.
Been over a year since buying the kit and since have moved to a larger property with a 40x50 shop. Room to breathe! Only stripped the shocks and coils out so far. Hope to do more.
Share this post
The fun begins when you try and fish them bolts over the rear shock brace I had to shut the garage door so the neighbors couldn’t hear all the adjectives that would come out of mouth
Share this post
I have the tendency to make my projects more difficult. I just replaced the old KYB rear shocks with Bilstein shocks. (I'm using Viking coil-overs in the front)
I wanted to replace the cheap 50 year old 5/16" bolts with some ARP 12 point 3/8" bolts I had kicking around.
Laying on the floor, working around 3" tail pipes, I had to drill the chassis holes bigger. The ARP bolts I had were too long so I had to poke them UP through the shock and catch a washer and nut above. Of course, they're prevailing torque nuts so they were difficult to turn for their entire length
I'm my own worst enemy.
Share this post
I found removing the old bolts easy by they may be short compared with the ones in the kit. Haven't opened the boxes yet.
I can only imagine the frustration of having to install the bolt the other way blind while holding a bracket.
Share this post
Currently I'm struggling with a frozen lower arm bolt. I think it's seized to the sleeve inside the rubber. Muffler is in the way so I can't hit it directly so I'm using a punch from the side. If I had an air chisel I think it would make short work of it but I don't have one. Other options are cutting the bolt and replacing it or removing the muffler to hit it directly with a bfh.
Share this post
After fighting with a lower control arm bolt that was rusted to the sleeve of the arm, it is free and I can move on with my install. That took way too long to get done.
Share this post
Here's everything that comes with the full kit. I opted to get the wrenches as well. I also bought another set of front springs for the 454 eventually. Currently running a 350 still.
Share this post
For the rears you will need a 5/8 drill bit for the lower shock mount to clean out the paint. I had to do it to mine to get the bolt through.
Share this post
So an update :
I've got the rear all but finished. I'm getting a bind in the passenger side trying to put the lower control arm bolt through where the arm seems twisted and will not line up. I had 2 thanksgiving dinners 2 days apart this weekend as well so didn't have the free time to devote to solving this. I can see the appeal of articulated rod ends in the case of the bind though.
Anyone who has installed the rear kit, did you use the relocation holes for the lower control arms? I've seen pictures of  people continuing to use the stock location and just do not know what the need for the relocation is. The brackets that came in my kit are from umi performance.
Sadly my exhaust is in the way as well so I will probably have to dump before the axel now.
Share this post
After a long wait, the rears are installed. I took it for a quick drive and while it seems ok, I'm not sure I like the ride height. I have raised the coil to about an inch from max and I'm maybe where I was when I started. Not sure if the mounting bracket is a significant drop over stock. Didn't drive it enough to notice any different handling characteristics yet. Front isn't done yet either and its the end that really needs it.
I'll have to crank up the rear spring a bit higher to see if I can get the height where I want it. I swear when I looked at a kit that mounted to the rear, there was an option for increasing the ride height. Might have seen something else I guess.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
