201fireman
Electric Fans
For those with electric fans, do you have them wired to keyed power so they go off when the key is off or direct 12 volt so they keep running after the car is shut off?
Share this post
Most electric fans are controlled by a thermostatic switch you stick on the radiator. Or a switch you control but there will be times you forget to turn it on.
With the thermostatic switch, if you wire it without key on control, it'll run anytime the switch says it's hot.
Running the fans with the engine off cools whats in the radiator more than with the engine on-but the engine will still heat soak after shut down.
If you have an electric water pump, you can let that run after shut down to avoid heat soak, the radiator fan doesn't need to be running.
I have a delay off relay controlling my pump. Key on the pump runs. Key off the pump shuts after ninety seconds.
Share this post
Its been awhile since my has run, but it is wired so the fans run after the car has been turned off and once it reaches the cool down temp the control box then cuts off.
Share this post
I have my fans on a switch (same one that controls my trans cooler fan) so it is not controlled by the ignition, it is controlled by a temperature probe after the switch is on. When I turn the switch off the fans will run for maybe 2 minutes then automatically turn off. I do have separate over ride switch that I can turn them on anytime and keep them going
Share this post
Create an account
Register a new account
Sign in
Sign In Now
