MikeParker Posted June 24, 2018 Share Posted June 24, 2018 Need some help - doing bench to buckets conversion on my 70... steering column shifter to console. New shifter is in place. For the console, I need a jumper harness, and I searched Luttys - found this part number: CH85108 -- here's the link: https://www.luttyschevy.com/i-20838111-console-harness-ch85108.html#!year%3D1970%7C%7Cmake%3DCHEVROLET%7C%7Cmodel%3DMONTE%20CARLO Is this what I need to go between the column and the console?? Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted June 24, 2018 Share Posted June 24, 2018 No, that is the console harness. You need the extension harness that goes from the dash harness to the console harness. Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted June 24, 2018 Share Posted June 24, 2018 Your dash harness will not have the plug to connect the extension harness to it. You will have to tap into a White wire, an Orange wire and a Gray wire in your dash harness. The White ties into the door jamb switch for your console courtesy light at the rear of the console. The Orange ties into a constant hot for constant power for the courtesy light. The Gray ties into the dash lights for your shift indicator lights on your console top plate. Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted June 24, 2018 Share Posted June 24, 2018 Does your console have a harness in it? Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted June 24, 2018 Share Posted June 24, 2018 I can not seem to find what you need on that site. It should cost about $45.00 for the extension harness. NPD Chevelle has what you need. They should have it in stock. Quote Link to comment Share on other sites More sharing options...
John S Posted June 24, 2018 Share Posted June 24, 2018 Try this website http://www.wiringharness.com/ John S Quote Link to comment Share on other sites More sharing options...
MikeParker Posted June 25, 2018 Author Share Posted June 25, 2018 Thanks for your help! I searched NPD and found the following ( IN STOCK TOO!! ) https://www.npdlink.com/product/harness-console-extension-oe-style-repro/113278/7304?year=1970 is the what I need to get? Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted June 25, 2018 Share Posted June 25, 2018 Yes, it is. Quote Link to comment Share on other sites More sharing options...
MikeParker Posted June 26, 2018 Author Share Posted June 26, 2018 Thanks Dan - I ordered it yesterday -- much appreciated, Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted June 26, 2018 Share Posted June 26, 2018 Your welcome. Quote Link to comment Share on other sites More sharing options...
