willie Posted September 24, 2018 Share Posted September 24, 2018 Are our battery cables the same length as the chevelles? If not where do I get a new set from? Thx Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted September 24, 2018 Share Posted September 24, 2018 Willie, I thought they were different. I got my original style top mount cables from Lutty's. You can go to their site to see hat they have available. You could also call them direct to ask if they are different than the Chevelle. On their site it looks like the list some of the Monte ones as different but others they have labeled as interchangeable. Here is their link. https://www.luttyschevy.com/search.html?#! I also looked at The Parts Place Willie. It looks like the part numbers they stock are different between the Chevelle and the Monte Carlo rob Quote Link to comment Share on other sites More sharing options...
1970mcss Posted September 24, 2018 Share Posted September 24, 2018 Willie, I ordered AC Delco cables from Rock Auto. Perfect fit. Good luck Quote Link to comment Share on other sites More sharing options...
overdrive Posted September 24, 2018 Share Posted September 24, 2018 Willie, is it for a top post, or the heavy duty battery with side posts for an SS? I called American Autowire with my buildsheet codes for our SS cables. They are longer than Chevelle. Dan Quote Link to comment Share on other sites More sharing options...
willie Posted September 24, 2018 Author Share Posted September 24, 2018 Thanks Guys. I will give them all a shout to see what I need. Yes Dan it is the HD battery with side posts. Thanks Again Everyone Quote Link to comment Share on other sites More sharing options...
overdrive Posted September 26, 2018 Share Posted September 26, 2018 I have the part numbers you need. They are on the cables. I'll try to remember to look tomorrow evening. Dan Edit: 10/12/18, I checked mine and there are numbers on the cables, but they aren't the numbers that American Autowire uses for ordering. Quote Link to comment Share on other sites More sharing options...
overdrive Posted September 27, 2018 Share Posted September 27, 2018 American Autowire- Positive is 21745, Negative is 21760. Dan Quote Link to comment Share on other sites More sharing options...
willie Posted September 28, 2018 Author Share Posted September 28, 2018 Thanks Dan I will give them a call also Quote Link to comment Share on other sites More sharing options...
overdrive Posted September 28, 2018 Share Posted September 28, 2018 I forgot to tell you, they manufacture the cables that many others sell. Dan Quote Link to comment Share on other sites More sharing options...
Vaughn Posted October 6, 2018 Share Posted October 6, 2018 Great info everyone. Thanks for the part numbers Dan 1 Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted October 26, 2018 Share Posted October 26, 2018 As I recall, all 1970 cars had top post batteries. Starting in 1971, GM switched to the sealed side posts that we still have on cars today. Battery cables are different from the Chevelle because the battery in the Monte is about six inches further away from the engine. The positive cable goes through a clamp under the upper bolt of the idler arm. 1 Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted October 26, 2018 Share Posted October 26, 2018 Just as I remember it also, I believe top post were BCI group 24, and side post were BCI group 71. According to: The Lester catalog index and The Battery Council International (BCI) is the primary trade association of OEM and after market battery manufacturers. Quote Link to comment Share on other sites More sharing options...
overdrive Posted October 27, 2018 Share Posted October 27, 2018 Not true about top post only in 1970. I gave American Auto Wire my cable and battery codes from my build sheet to get the correct cables and battery. The heavy duty battery, R79W for SS cars, (and others with that option) is a side post. The positive cable code is NH, and the negative is LC. My car came from the factory with a clamp for the positive cable on the bolt for the motor mount perch, where it bolts to the frame. It's number 6 in the assembly manual pic. It did not have the clamp on the idler bolt, but our '71 small block car does. I've seen them on a number of Montes. I ended up putting both on my SS when I restored it. Dan 1 Quote Link to comment Share on other sites More sharing options...
overdrive Posted October 27, 2018 Share Posted October 27, 2018 Also, the negative cable should bolt to the block, not the alternator bracket. At least, I know this to be true on 2 Van Nuys built SS '70s. Mine and Jim Shneider's came that way. His is an unrestored car with 52k miles. Dan Quote Link to comment Share on other sites More sharing options...
1970mcss Posted October 28, 2018 Share Posted October 28, 2018 I had a mechanic friend of mine suggest that the negative cable run to th block. Is the bolt for the exhaust manifold or just for the cable. I haven't looked at my car yet. Quote Link to comment Share on other sites More sharing options...
overdrive Posted October 30, 2018 Share Posted October 30, 2018 The cable bolts directly to the block. This pic is of Jim's 52k mile car. He maintains it, of course, but keeps everything he can as it came from the factory. Dan Quote Link to comment Share on other sites More sharing options...
1970mcss Posted November 1, 2018 Share Posted November 1, 2018 Dan, thanks for the picture and the info. I rerouted the cable with a new bolt, the cable looks so much better mounted to the block rather than to the alternator bracket. Quote Link to comment Share on other sites More sharing options...
