Blake350 Posted November 4, 2018 Share Posted November 4, 2018 Two quick questions...need to replace the turn signal indicator bulbs on dash- thought I had lost right side blinker but it was only the indicator out...what is easiest way to get at them?? is it with dashpad removed? Also since day one ,turn signals have flashed very slow--an upgrade to flasher maybe?it is all original '72 flasher and incandescent bulbs thanks! Brian Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted November 5, 2018 Share Posted November 5, 2018 Yes, remove the dash pad to access the bulbs, but the very first thing you will want to do is remove your negative battery cable so that you do not smoke your printed circuit board while you are behind the dash. This is a VERY important thing to do. A must. Then replace the bad bulbs. There are 6 screws holding the dash pad down. Remove the screws, then lift the front of the pad up and pull the pad toward you. There are six clips holding the pad down on the windshield side of the pad. Be sure not to loose any clips. Try a new flasher. 1 Quote Link to comment Share on other sites More sharing options...
