Factory Power Window Setup Electric Life Repro Square
sendo
Local friend used that in his Monte..... it worked.... He said it was no big deal to install. With the exception of taking the doors off to drill the holes through the doors and cowl it's not that difficult to add power windows. I've done it twice but using factory stuff. I don't see the boots for the wiring when it passes through theĀ  door to the cowl. I would also see if you can get a copy of the directions to see how it's wired into the fuse box and that the motors use the factory holes for mounting.
Steve
