Sign in to follow this
sendo
old/new member
been here awhile, but now a new owner and paying member.
does anyone have a wiring diagram my horn is not working
Share this post
Remove the horn shroud to see if the wire harness on the shroud for the horn buttons is properly connected to the plastic tube on the canceling cam. You could also test the horn by itself to see if it will blow with power and a ground put to it. Did you change anything since it last worked?
Share this post
The wiring diagrams for the 70 are in the "Electrical Forum".  The horn wiring for the engine compartment, including the horns and horn relay are in the first diagram and the second diagram has the interior wiring.
The horns pick up their ground from being bolted to the hood release bracket so first make sure you have continuity  from the negative terminal of the battery to the horn mounting.  If that is good then run a wire directly from the positive terminal directly to the horn wire terminal.  They should blow.
If not it could be a bad horn relay or trace the wires back to the firewall terminal blocks or in the steering column itself.
Share this post
Welcome and congrats on the new SS. Looks like a great car. When I bought mine it also had a horn that didn't work. I used a test light to test the horns. In my case it was the horn relay.
Share this post
how long does it take to get the FGMCC badge under your name?
Share this post
Done :)
Share this post
Create an account
Register a new account
Sign in
Sign In Now
