Guest cstraub Posted May 20, 2008 Share Posted May 20, 2008 Now available from Morel is the Perfect Roller lifter. . .runs on a hyd roller or a SOLID roller lobe profile. After months of spintron testing, live engine testing, and field testing a new lifter is available to the enthusist. Morel has taken its technology in materials and body design of solid roller lifters and built the ultimate hyd roller. This lifter features an upgraded body, roller, and axle. The stainless tie bar is connected to a 3 button system to prevent binding and premature failure. The valving system has been tweaked to prevent valve float to a tested 7300 rpm. Last but not least the bodies are REM finished. Iin back to back testing in a BBC application this lifter proved to make 34 more HP over a std hyd roller lifter and an increase in additional rpm when used on the same cam profile. The lifters when used on solid roller cams do have their limits. Spring pressures should be a max of 220# on the seat and 550# open pressure. This new generation of lifter is recommened for severe street strip use and extended marine applications. You can now have you Solid roller and no lash adjustment..... Link to comment Share on other sites More sharing options...
Mike 57 Posted May 21, 2008 Share Posted May 21, 2008 Where are they available from? and what type of pricing? Link to comment Share on other sites More sharing options...
Guest cstraub Posted May 21, 2008 Share Posted May 21, 2008 100% USA made in Cleveland OH. Link to comment Share on other sites More sharing options...
Guest cstraub Posted May 21, 2008 Share Posted May 21, 2008 Same lifter... Link to comment Share on other sites More sharing options...
Sam (Bones) Posted May 21, 2008 Share Posted May 21, 2008 sounds like the new hot ticket Link to comment Share on other sites More sharing options...
