aluminum heads
71monteme
i have a chance to get a pair of aluminum heads from a zz572 bbc engine for a great price. can you guys and gals tell me if these heads will fit on a mark IV block? thanks
thanh.
here's the specs
Bowtie 572/620 Cylinder Head Assembly
MSRP
$1,415.71
Buy
Enlarge image [+]
12499255
Aluminum head assembly
Used in the 572/620 GMPP crate engine
Completely assembled with 2.25/1.88 11/32 stem valves
Valve springs for hydraulic roller cams for up to .632 lift
310cc rectangular intake port
118cc exhaust port raised 5/8
118cc combustion chamber
Not recommended for engines smaller than 572 cid
This head is assembled with the following components:
12366987 2.25 Intake Valves
12366990 Valve Spring Retainers
88963128 Exhaust Valves
12366992 Valve Locks
88963934 Valve Springs
88963936 Valve Seals
88963937 Valve Spring Shims
3921912 Rocker Arm Studs
88963935 Valve Spring Locators
3860038 Pushrod Guideplates
and this is the 720hp head
Bowtie 572/720R Cylinder Head Assembly
MSRP
$1,465.71
Buy
Enlarge image [+]
88961160
Aluminum racing head assembly
Used in the 572/720R GM Performance Parts
Mechanical roller valve springs not for use with hydraulic roller cams
Good to .720 valve lift
88963933 Valve Springs
thanks guys.
i knew you guys would get me in the right direction.
bones- where did you get the spec and Msrp?
allen- yes it would be a nice treat but i might have a 565 rhyes- morrison @ 1000hp going into the monte for a few runs before we trade it in for another 565@ 1400hp laugh. i'll find out what is the weakest link in the car crazy
thanh
I'm once again in agreement here with Allan. For my money I'll stay with AFR for the rest of my life. My 315's on my 489 work like a charm. If I ever step up to real big league displacement AFR has either a set of 335, or 355 CNC heads that will definitely do the trick.
