wallaby Posted August 20, 2006 Share Posted August 20, 2006 I'm just wondering from you guys that have "been there, done that": how much difference will be noticed at the dragstrip by using drag tires? I have a torquey big-block and right now I have to "roll" into the throttle to keep the tires from spinning. Will drag TA's make a big difference, or would it be wiser to just step up to slicks for the few times I get to the strip? Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 20, 2006 Share Posted August 20, 2006 ain't nothing like having a set of STICKYS worth every penny to me HOOK&BOOK Link to comment Share on other sites More sharing options...
Guest Posted August 20, 2006 Share Posted August 20, 2006 I USE THE MT ET STREETS AND THEY HOOK GREAT AND YOU CAN DRIVE THEM ON THE STREET !!!! they ride nice on the street, but I wouldn't recomend driving in the rain though, that's the only draw back, but man it's great not having to change tires at the track, just let a little air out and your ready to go. Link to comment Share on other sites More sharing options...
Reaper Posted August 20, 2006 Share Posted August 20, 2006 How many miles you figure drag radials are good for? guesstimate Link to comment Share on other sites More sharing options...
502ci Posted August 20, 2006 Share Posted August 20, 2006 Get a pair of slicks. I`ve used BF Goodrich drag radials at the track and they do not remotely compare to slicks. Of course there are really fast cars using drag radials and they will tell you different, but even with a fairly stock suspension a set of slicks will make your car hook. My dad uses the cheater slicks and has no spinning problem but I`m not sure you would want those unless you plan on leaving them on all the time. Another thing to consider is at the track (at least at mine) when running slicks on a day when they are having test and tune, you will get more runs in. At my track there are fewer cars testing that have slicks so they usually run half the street class then come back to the not street legal lanes and run them again. I use the Mickey Thompson ET drag tires. Size...28/10.5-15S The S stands for stiff sidewall, every thing I read and every person I talked to said go with the stiff sidewall. Unless you have no suspension then go with the soft sidewall so it can absorb the shock of the launch. Plus at the top end the stiffer sidewall tires give better control with a heavy monte. I`ve driven them to the track (45 minutes one way) with 28 lbs in them and they ride actually nice. Link to comment Share on other sites More sharing options...
502ci Posted August 20, 2006 Share Posted August 20, 2006 Reaper... I have about 6,000 miles on mine and the wear indicator is getting close to the tread depth. I will continue to drive mine past the wear mark. Rain will be the factor at one point. I ran mine at the track for a couple years so alot of tread went up in smoke , so it depends on what you do with them as to how long they will last. I`ll say this though I will never put a standard street tire on the back of my car again. Part throttle would spin them (dangerous). Now it takes about twice as much throttle to get them going. Link to comment Share on other sites More sharing options...
Reaper Posted August 20, 2006 Share Posted August 20, 2006 6000 miles and still going is a lot better then I thought you were gonna say Link to comment Share on other sites More sharing options...
wallaby Posted August 20, 2006 Author Share Posted August 20, 2006 Well I figured slicks would be the best choice, but I guess my question is whether any of the DOT race tires like the drag radial, quick time, etc, are much better than a similar-sized street tire. ...and do you need to heat them up? Link to comment Share on other sites More sharing options...
Guest Posted August 21, 2006 Share Posted August 21, 2006 the first pass of the day you need to heat them up like this to wake the compound up......... and after that just heat them up enough to get the crap off of them. Link to comment Share on other sites More sharing options...
502ci Posted August 21, 2006 Share Posted August 21, 2006 Wallaby... Yes the drag radial is worth it if you don`t go with the slick, yes you do heat them up. I don`t go in the water but haze them to get them sticky. If I`m doing it for a photo then its a John Force burnout Link to comment Share on other sites More sharing options...
502ci Posted August 21, 2006 Share Posted August 21, 2006 I keep hearing the Mickey Thompson drag radial is best right now. I myself will try them for my street tire when my current ones wear out. The one draw back is on the street when you go to do a rolling burnout (to show off) these type of tires hook-up so it appears to every one that you don`t have as much power . Link to comment Share on other sites More sharing options...
mc71454 Posted August 21, 2006 Share Posted August 21, 2006 Post your MPH in the 1/4 or 1/8 and I can tell you what ET you could expect from a drag tire.. Link to comment Share on other sites More sharing options...
mc71454 Posted August 21, 2006 Share Posted August 21, 2006 I keep hearing the Mickey Thompson drag radial is best right now. I myself will try them for my street tire when my current ones wear out. The one draw back is on the street when you go to do a rolling burnout (to show off) these type of tires hook-up so it appears to every one that you don`t have as much power . ....Except if your front tires come off the ground Link to comment Share on other sites More sharing options...
502ci Posted August 21, 2006 Share Posted August 21, 2006 ....Except if your front tires come off the ground This is true... Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 21, 2006 Share Posted August 21, 2006 I like running street tires, I can pretend I'm one of those "drifters", that's why I love rear wheel drives in the snow Link to comment Share on other sites More sharing options...
Guest Posted August 21, 2006 Share Posted August 21, 2006 Humm I haven't run street tires for about 5 years, I forgot what it was like to do some nasty street tire burn outs, hummmm I'm going to go steal the tires off of my wifes car. Link to comment Share on other sites More sharing options...
502ci Posted August 21, 2006 Share Posted August 21, 2006 Ahhh, now I know how to beat you Sam, just catch you on the street then I can hammer it while you just sit there spinning. Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 21, 2006 Share Posted August 21, 2006 it wouldn't be the first time!!!! Link to comment Share on other sites More sharing options...
wallaby Posted August 22, 2006 Author Share Posted August 22, 2006 Last time out I ran 104 mph. Link to comment Share on other sites More sharing options...
MeanMonte Posted August 22, 2006 Share Posted August 22, 2006 I have the M/T drag radials pretty nice very soft for a street tire suposed to be best one out and there are people runing insane numbers on them. I havent tried to go down on pressure to much yet but they make a huge difference! Link to comment Share on other sites More sharing options...
Guest Posted August 22, 2006 Share Posted August 22, 2006 Last time I was at Moser they had a couple of sets of the big gun drilled axles up there with the spline end shattered! I talking 35 and 40 spliner's! Both sets were from radial tire racers that switched to the MT drag radial! Both were new axle sets installed and broken on the first outing. The Mt radials bite very hard and the sidewalls don't give so the axle take a harder shock. Takes a lot of traction to shatter an axle regaurdless of the tire sidewall. Long story short the MT drag radials are some bad MOFO's!!! Don Link to comment Share on other sites More sharing options...
Cali Z28 Posted August 24, 2006 Share Posted August 24, 2006 Ive been using the M/T ET streets for 5 years now, 26 10.5 16, my 60 foots have been in the 1.58 to 1.63 range running 11.50's at 116. My new motor is going require a taller and wider tire so 28 11.50 15's are on the way, but im going to get a set of those new MT radials for the street, have heard great things about them. Scott Link to comment Share on other sites More sharing options...
71monteme Posted August 26, 2006 Share Posted August 26, 2006 got me a set of the new m/t drag radial. will see how they compare to the et-street. i'll post result. thanh Link to comment Share on other sites More sharing options...
