Andreas Posted January 26, 2001 Share Posted January 26, 2001 For all of you Modifiers and maybe some who have done it already (you have my sympathy): I have started the venture yesterday to install a B&M Megashifter in my bench-seat Monte. So far, I have it bolted down to the tranny tunnel and preliminary routed the cable. Getting these nuts in with the tranny installed is a real pain (I did not want to drop the tranny). At least I could test-shift yesterday without being hooked up to the tranny. Damn, that thing feels good! I will keep y'all posted on the progress (with pics, of course ). ------------------ 71 Monte 383 "The Full Monty" 86 Monte LS ZZ4 "The Gray Mouse" http://go.to/Monte Member NMCOA, FGMCC "It ain't a car if it's not a Monte" Link to comment Share on other sites More sharing options...
Guest Posted January 26, 2001 Share Posted January 26, 2001 i installed a megashifter in my 72' when i did all of the work last year, but i have buckets and the shifter is set back a little, not forward. i think the most trouble that i had was drilling the hole for the cable to go through. screwed up once and had to drill another. other than that, it wasn't too bad. good luck with the installation. have fun, it's a kick [you said a naughty!] shifter. Link to comment Share on other sites More sharing options...
Chevymd350 Posted January 26, 2001 Share Posted January 26, 2001 I have the chance to get one of these shifters, i'm looking at that one or a hurst promatic 2 ratchet shifter to put in my bench seat 70. Is there any thing I could do before I put the tranny in to make the job easier? Thanks alot MAtt Link to comment Share on other sites More sharing options...
Andreas Posted January 26, 2001 Author Share Posted January 26, 2001 To make it easier, do not put the tranny in. Its is 100% easier to install the shifter with the tranny out of the car. ------------------ 71 Monte 383 "The Full Monty" 86 Monte LS ZZ4 "The Gray Mouse" http://go.to/Monte Member NMCOA, FGMCC "It ain't a car if it's not a Monte" Link to comment Share on other sites More sharing options...
Guest Posted January 26, 2001 Share Posted January 26, 2001 Ah good, thanks for the info, same shifter (likely) is goin' in the '72 next month along WITH a new tranny, so it's good to know to do the shifter first . Link to comment Share on other sites More sharing options...
Grease Posted January 27, 2001 Share Posted January 27, 2001 cables instead of shift rods ? gosh its been a long time since i been hotrodding mike Link to comment Share on other sites More sharing options...
Andreas Posted January 27, 2001 Author Share Posted January 27, 2001 Well, wanna floor shift but you have a bench seat? You do not have the $$$ to shell out for bucket seats and a console? Here is the solution: After almost twisting my fingers off to secure the last nut (reminder to myself: next time install a floor shifter when the tranny is out of the car!!), the B&M Megashifter is in!! Have made all the adjustments, but not tried it out on the road yet (Monte is still waiting for paint "stripped down"). But Boy, it really feels and looks good. you can slam it as hard as you want between neutral and L1 and still go up/down only one gear (ratchet). Still have to trim the base to fit the tranny tunnel 100%, but I put it in anyways. Digital cameras are a great thing, so go look at the pics of the installed shifter at http://go.to/Monte Hope you do not mind the missing doorpanels and other missing interior parts... I am a happy camper ------------------ 71 Monte 383 "The Full Monty" 86 Monte LS ZZ4 "The Gray Mouse" http://go.to/Monte Member NMCOA, FGMCC "It ain't a car if it's not a Monte" Link to comment Share on other sites More sharing options...
Guest Posted January 27, 2001 Share Posted January 27, 2001 Andreas, that looks excellent. I bet you are more than happy to deal with the busted knuckles since the end result looks so outstanding! You are definately one of the driving forces that gives others the insperation (sp?) to continue working on there Montes. ------------------ 72 Monte Carlo Webpage for my Monte Carlo http://darkforcemaster.tripod.com/pics/index5.html Link to comment Share on other sites More sharing options...
Guest Posted January 27, 2001 Share Posted January 27, 2001 The shifter install turned out great, andreas. You just have to take out the column shifter rod. Link to comment Share on other sites More sharing options...
Andreas Posted January 27, 2001 Author Share Posted January 27, 2001 Yeah, I am just waiting for a couple of test drives before I take all the stuff off the column... You never know ------------------ 71 Monte 383 "The Full Monty" 86 Monte LS ZZ4 "The Gray Mouse" http://go.to/Monte Member NMCOA, FGMCC "It ain't a car if it's not a Monte" Link to comment Share on other sites More sharing options...
