Message Board
2018 Western Meet
[clock1]
2018 Eastern Meet
[clock2]
c-clip eliminators.
  • Please log in to reply
25 replies to this topic
#1 71monteme
71monteme
    Silver Member
  • Members
  • 1,071 posts
  • Locationunionville, CT 06085
  • Occupation:manager
Posted 04 March 2006 - 10:12 AM
hi guys.
what is involved in instaling these units? do you have to buy new axles to do this or can you use what you have? i know i will have to take the axles out of the housing. how are the bearing stay on the axle?
any one done this please feed me some info.
thanks.
thanh
505bbc. Some day it will be done. yeah right.
#2 Sam (Bones)
Sam (Bones)
    FGMCC Treasurer monteholic moderator
  • Administrators
  • 17,777 posts
  • LocationOrtonville,Mi
  • Legal Name:monteholic
  • Occupation:Aviation Ground Equipment & Support Technician
Posted 04 March 2006 - 10:45 AM
they make kits for this w/ new axles, after you remove your axles you will have to remove the backing plates, remove the seal & bearing, cut off the end of the axle, reinstall backing plates, slide the new axle in w/the bearing assem installed on the axle, the new axle bearing assem bolts to the axle using the backing plate bolts (new ones), the new bearing assem is what holds the axle in, I think mine was from Moesure
Sam
Sam
70 & 71 montes
#3 71monteme
71monteme
    Silver Member
  • Members
  • 1,071 posts
Posted 05 March 2006 - 03:58 PM
sam.
do you drive your on the street? did you do the work yourself?
i read that they leak real bad if driven on the street.
thanks for the info.
thanh
#4 Sam (Bones)
Sam (Bones)
  • Administrators
  • 17,777 posts
Posted 05 March 2006 - 04:28 PM
thanh,
yes I drive it about 1500 miles a year, no prob so far, and I did it my self, I'm an ex truck mech. not to hard, when you seal it just remember, CLEAN< CLEAN<CLEAN, then leave it for a day for the sealer to completely cure, lock-tite everything laugh good to go!!!
what do you run now??? laugh
Sam fgmcc
Sam
70 & 71 montes
#5 71monteme
71monteme
    Silver Member
  • Members
  • 1,071 posts
Posted 10 March 2006 - 08:21 PM
sam
thanks for the info. 11.20 so far . i'm trying to get into the 10's this year so i'm looking at the areas where the car is weak. i wanted to start with the rear end as i think it is the weakest link right now. also the safety issue. don't want a wheel/axle assembly leaving the car at high speed.
thanh
#6 Sam (Bones)
Sam (Bones)
  • Administrators
  • 17,777 posts
Posted 10 March 2006 - 08:43 PM
thanh,
I've run a 11.59 best lookin for more, have a few ideas :rolleyes:
Sam
Sam
70 & 71 montes
#7 71monteme
71monteme
    Silver Member
  • Members
  • 1,071 posts
Posted 11 March 2006 - 03:02 PM
sam
i'm lighten up the front end with fiberglass fenders, a shot of 100hp nitrous. and i hope to be in the 10's.
#8 Sam (Bones)
Sam (Bones)
  • Administrators
  • 17,777 posts
Posted 11 March 2006 - 06:07 PM
I just want 11.0's, gonna change the engine some, no bottle, all throttle, I'm 3650#'s w/o me
Sam
Sam
70 & 71 montes
#9 502ci
502ci
    MODERATOR in the 11's
  • Moderators
  • 15,356 posts
  • LocationRichfield, Ohio
  • Legal Name:Bill
  • Occupation:Union Electrician / Local 38/Commercial, Industrial
Posted 11 March 2006 - 08:29 PM
Really? Why not a 10.99?
Bill
Molôn Labe
11.80's at 114 mph, 0-60 in 3.34 sec.____
Click here to see my never ending project
__________Click here to hear it__________
#10 Sam (Bones)
Sam (Bones)
  • Administrators
  • 17,777 posts
Posted 11 March 2006 - 09:04 PM
that would be ok, I just don't want to get to crazy
Sam
Sam
70 & 71 montes
#11 Sam (Bones)
Sam (Bones)
  • Administrators
  • 17,777 posts
Posted 12 March 2006 - 06:30 AM
thanh, Bill
have you up-graded your rear suspension at all???
Sam BB
Sam
70 & 71 montes
#12 502ci
502ci
  • Moderators
  • 15,356 posts
  • Legal Name:Bill
Posted 12 March 2006 - 07:56 AM
Sam... I`ve installed QA1 rear 12-way adjustable shocks,
Hotchkis rear lowering springs,
adjustable rear spring spacer (sits under the spring on the perch), adjusts from 0 to 4", it can be used to preload right rear tire or lift both sides, adjusts in seconds with a socket set,
Hotchkis rear sway bar,
edelbrock double adjustable rear upper control arms,
edelbrock boxed rear lower control arms,
edelbrock tubular rear braces (for strength and to accurately locate rear suspension).
The rear end is from a 70 chevelle, with a 4.11 posi, added moser c-clip axles with 1/2" wheel studs. smile
Bill
Molôn Labe
#13 Sam (Bones)
Sam (Bones)
  • Administrators
  • 17,777 posts
Posted 12 March 2006 - 08:01 AM
Bill,
I've never heard of those adjustable spacers, where did you get them??? I want a set laugh
Sam
Sam
70 & 71 montes
#14 502ci
502ci
  • Moderators
  • 15,356 posts
  • Legal Name:Bill
Posted 12 March 2006 - 08:32 AM
Heres the link... http://www.budzter.com
These spacers are nice and heavy duty. cool
Bill
Molôn Labe
#15 Sam (Bones)
Sam (Bones)
  • Administrators
  • 17,777 posts
Posted 12 March 2006 - 09:22 AM
thanks Bill,
those are great, gotta have a set laugh
Sam
Sam
70 & 71 montes
#16 71monteme
71monteme
    Silver Member
  • Members
  • 1,071 posts
Posted 12 March 2006 - 10:11 AM
bill,
those adjuster looks great, it does kinda the same thing as the air bags do.
sam.
the only thing i did to the rear suspension is install a set of South Side Machine lift bars, heavy duty coil springs. everything else is stock.
will be installing airbag in the right rear coil spring this year.
thanh.
BB
#17 Sam (Bones)
Sam (Bones)
  • Administrators
  • 17,777 posts
Posted 12 March 2006 - 11:45 AM
I put air bags in mine, hotchkiss lower control arms, and no-hop adapters, need to do the uppers and braces
Sam BB
Sam
70 & 71 montes
#18 mc71454
mc71454
    Brass Member
  • Members
  • 295 posts
  • LocationAlbany NY
  • Occupation:Civil/Environmental Engineer
Posted 24 April 2006 - 06:35 PM
Nice Ride Sam...
Hey Thanh, what is your race schedule this year? We need to meet up at LVD this year...
Tom Baird - '71 Monte - NA, 10.310 @ 129.86 mph, 3950 pounds, 3.73 gears, pump gas driver
'70 Chevelle SS 454, 12.30's
'87 Buick Turbo T Limited, Stock
'87 Monte SS Aerocoupe, Stock
'07 Toyota Tundra 4WD, mods
#19 mc71454
mc71454
    Brass Member
  • Members
  • 295 posts
  • LocationAlbany NY
Posted 24 April 2006 - 06:36 PM
Thanh,
I use the Mark Williams Kit. Installed it about 5 years ago. Very easy install and no leaks...
#20 71monteme
71monteme
    Silver Member
  • Members
  • 1,071 posts
Posted 25 April 2006 - 08:21 PM
hey tom.
good to see you posting here. do you have to use their axles with their kit? i know strange said their kits are only for their axles.
it looks like we will be at LVR on the 6th of may if the weather is good if not then the first saturday that the weather is good. hope to meet up with you.
thanks.
thanh.
Home Page
Message Forum
Members' Montes|Meet Photos
