BRAKE CALIPERS REBUILD ORGIONAL OR BUY NEW
Done many calipers, its not that bad but there some special tools required. Air is a must to remove the piston and remember dont try to stop the piston when coming out with your hand that hurts real bad, put a block of wood in there. make sure the bleeder screw comes loose first. after you get the piston out inspect it and the housing very carefully, any pitting its junk. remove all the old seals and Clean everything up and real good. Install the square cut o-ring and install the boot (outer seal) on the piston. useint the old pad press the piston back in with the piston installer tool then put the outer part of the seal on with the seal installing tool. Install all the new o-rings and bushings. all seals HAVE to be installed with silicone lube, some use spray I use paste thin layer does it. Its not that bad depending on how the old ones are. good luck, Steve
i watched a video of a technician that did it without tools but be good to have. i think can get get by with what i got but i will prolly buy next time snap on is here. i still can find seal driver specifically for calipers.
Do any of the parts stores in your area have one of those loan a tool programs. You rent the tool for the selling price and when returned you get a full refund. I have used them her in Central Indiana many many times over the years.
I would think twice about the time, tools and cost of materials to rebuild this low dollar, common stocking item. I just recently purchased from NAPA, 2 GM stamped, remanufactured calipers,(from an American company) black powercoated and 2 year warranty for 34.99 each. Black or silver painted finish calipers were 29.99 each. They were installed with new NAPA Gold premium brake pads, bled and road tested in under 30 minutes. My car stops super straight, and now on a dime. Unless you Monte is a 100% restoration, I don't believe it pays. Is it really worth your time and effort to rebuild ? I think it's great to try to learn something and rebuild various automotive parts, but at what cost?
I am at work right now and don't have access to it. I will take a look in my reciept file or call the NAPA store I deal with and get it for you. Please give me 24-48 hours to get you the part numbers. CK...
well it cost me 4.99 to rebuild one caliper. i aready have paint for calipers because i did rear ones. i rebuild calipers at work so time not an issue. i know what i got and i use wagner thermoquiet pads like i want. are those napa calipers rebuilt in us or china?
Joe, They are rebuilt in the USA. I would not use any foriegn or Chinese built parts. If you have access to the rebuild parts, tools, time and the proper knowledge or are a professional mechanic, that is absolutely the way to go. For the Monte owner who is not highly trained or does not have have all of the above, or limited time to work on their car, USA rebuilt calipers may be the way to go. CK...
I have been doing alot of research on made in usa stuff lately. if i cant find what i need i will rebuild. if these companys do indeed rebuild in the usa it is very hard to find out. i bought a caliper for my pickup a while back. there was nothing on it saying where it was done. you would think they would want you to know. i bought a water pump about 6 monthes ago and it was the same way. that was it for me. if you have the time there is plenty of info on the net and im always in for buyin some new tools. prolly the clean up and paint is the worst part. the calipers you bought were definatly worth the money. if my wife found out i spent that much right now id be in the doghouse. she is in nursing school right now and im the only income.
Yes. I will reach out to you over the weekend. Go easy with your money on the parts. Your wife's education comes first. Just think how much faster it will go with 2 incomes for parts !!! Thanks, CK
Ian, here are the NAPA part numbers as you requested. I confirmed the part numbers and price thru my local store that I deal with. They are $29.99 each, not $34.99 as I had said earlier, black powdercoated and also come with a 2 years of free roadside assistance! The part numbers are SE4590 Rightl side and SE4591 Left side.
You dont need the tools,all you need is air and a bottle of assembly fluid,same with wheel cylinders. The trick is getting the dust boot back over the piston. It's a lost art.After you get the dust boot started over the piston with proper lube the piston will slide right in.
This is starting to sound like a porno!!lol
