Guest Posted August 28, 2003 Share Posted August 28, 2003 Well I went and did it on a whim last night. I pulled my old grill off and grabbed my better condition grill out and taped it off and painted the little squares black. Now my question is, is this correct for a restoration on a grill. It's my 70 monet grill. I know it's alittle late to be asking but I'd just like to know just for my info. Jon. ------------------ Go Dale Jr. #8!!!! 1970 Monte Carlo Jaguar Racing Green Buckets with Factory Tach 408 s/b, KB Hyperuetectic flattops, Eagle SIR rods, Dart 200cc runner Iron Eagles( 2.05/1.60 valves)Comp Cams 294 Ext. Ener. Hyd. Cam, Comp magnum Rollertip rockers, Powerplus "Bowtie" Intake, Holley 750 HP series Carb, and lots of aluminum goodies! 350 Turbo Trans. 2800-3000 stall converter. Eaton Posi Ten Bolt 3.73 gear/ Moser axles. OLD 1/4 TIME: 13Sec.@103MPH. 1/4 Mile New 1/4 mile time: 12.8 sec in the 1/4 mile. Link to comment Share on other sites More sharing options...
Canuck Posted August 28, 2003 Share Posted August 28, 2003 As far as I know, it is only painted in the small groove that is near the top and down the sides. I wish I had a pic for you. ------------------ Aaron 1970 Misty Turquoise Monte Carlo My Monte Carlo Web Site If your wife ever says "Come and move this transmission so I can take a bath," You might be a Gearhead. Link to comment Share on other sites More sharing options...
iceman Posted August 29, 2003 Share Posted August 29, 2003 The squares should be silver but the wide groove around the squares should be black. ------------------ If you get out of your car without needing to change your pants, you weren't driving fast enough. 70 SS454 clone - Cortez Silver with functional cowl induction 70 SS454 Shadow Gray Link to comment Share on other sites More sharing options...
Guest Posted August 30, 2003 Share Posted August 30, 2003 Well then I screwed up. It still looks good, though they are not silver. I guess I'll just mask it back of again and get me some silver paint. I used that new "Fusion" paint by Krylon. It stuck!!!! Yeh to metal could'nt beleive it myself. Jon. ------------------ Go Dale Jr. #8!!!! 1970 Monte Carlo Jaguar Racing Green Buckets with Factory Tach 408 s/b, KB Hyperuetectic flattops, Eagle SIR rods, Dart 200cc runner Iron Eagles( 2.05/1.60 valves)Comp Cams 294 Ext. Ener. Hyd. Cam, Comp magnum Rollertip rockers, Powerplus "Bowtie" Intake, Holley 750 HP series Carb, and lots of aluminum goodies! 350 Turbo Trans. 2800-3000 stall converter. Eaton Posi Ten Bolt 3.73 gear/ Moser axles. OLD 1/4 TIME: 13Sec.@103MPH. 1/4 Mile New 1/4 mile time: 12.8 sec in the 1/4 mile. Link to comment Share on other sites More sharing options...
McCall72 Posted September 3, 2003 Share Posted September 3, 2003 I did my 72 grill a while back. I taped it off like you did, and used Argent silver with a thick clear coat. I also lightly scuffed the surface that was to be painted. The taping took a day and an age, but it turned out GREAT! Link to comment Share on other sites More sharing options...
Guest Posted September 3, 2003 Share Posted September 3, 2003 I kinda like the blaked out look. I did'nt cut all the squares out, I had a role of that expensive green body and fender masking tape and masked the front of the grill that would stay chrome and rubbed the tape down good so I would'nt get to much over spray on the chrome. Then I turned it over and painted the backside of the grill from 4 different dirctions to make sure I got good coverage. I also held the can about a foot and a half away to help with the overspray. I had a few spot I had to touch up but it came out pretty good. Jon. ------------------ Go Dale Jr. #8!!!! 1970 Monte Carlo Jaguar Racing Green Buckets with Factory Tach 408 s/b, KB Hyperuetectic flattops, Eagle SIR rods, Dart 200cc runner Iron Eagles( 2.05/1.60 valves)Comp Cams 294 Ext. Ener. Hyd. Cam, Comp magnum Rollertip rockers, Powerplus "Bowtie" Intake, Holley 950 HP series Carb,( yes a 950 HP carb) and lots of aluminum goodies! 350 Turbo Trans. 2800-3000 stall converter. Eaton Posi Ten Bolt 3.73 gear/ Moser axles. OLD 1/4 TIME: 13Sec.@103MPH. 1/4 Mile New 1/4 mile time: 12.8 sec in the 1/4 mile. Link to comment Share on other sites More sharing options...
