Message Board
Welcome!
[clock1]
[clock2]
Home Page  | How to Join  | Merchandise  | Chat Room | West Meet | East Meet | Members' Montes
FGMCC Meet Photos | Tech Info  | Museum  | Parts and Services  | Registry  | Links  | Club Officers
Page 1 of 3 1 2 3 >
Topic Options
Rate This Topic
#259201 - 04/26/10 09:40 PM Badly leaking 700R4 tranny- HELP !!
Stroker-383 Offline
Junior Member
Loc: Overijssel, The Netherlands
Hi all,
Have got some bad news, was driving my 1972 monte carlo yesterday ( sunday ), and suddenly my tranny starts leaking badly !!
I stopped immediatly and checked the underside of the car. It leaked pretty heavy ... but i'm not sure where the transmission fluid is leaking from .... I think it leaks between the torque converter and tranny.... so i was thinking :
- Leaking tranny seal...
- Leaking torque converter ;(
I will disassemble the tranny this week to check everything... Hoping to find something that is wrong. (thats leaking )
Hoping to find some information about checking the gears properly and checking the fluid... Also i noticed my dip-stick to check the transmission fluid is a bit loose... so that needs to be fixed as well... ( thinking of the fact that the dip stick is leaking ... that can be the problem... But then it wouldnt leak so badly, would it? )
I will update here as soon as I've got news.
Wish me the best;)
_________________________
There's just no substitute for cubic inches.
*Project 383 stroker*
"She's faster then a cheetah on cocaine!"
Top
#259213 - 04/26/10 10:17 PM Re: Badly leaking 700R4 tranny- HELP !! [Re: Stroker-383]
72MC Offline
Gold Member
Loc: MARSHALL, VA
I guess the biggest question I have is where is most of the evidence of new fluid showing up? Is it at the dipstick tube, the front pump, the pan edge, etc, etc? If I hear you correctly and it is dumping out, either the pan come lose or something broke structurally(ie., case, pump, convertor, input or output line, etc). I guess what I am saying is your definition of "leaking badly" is relative. Any pics?? - Dave
1972 Monte Carlo 383 w/4L80 full manl & posi 4.10 gears
1972 El Camino Custom 402 w/th350 & posi 3.31 gears
1996 Impala SS-SOLD
2013 Camaro 2SS/RS L99--Heritage--Chevy still the BEST
If Guns Kill People then Cars Drive Drunk
Top
#259230 - 04/26/10 11:05 PM Re: Badly leaking 700R4 tranny- HELP !! [Re: 72MC]
7tonemonte Offline
Its Sooooo GREEN!! FGMCC Treasurer
Double Diamond Member
Loc: Chester County Pa.
It depends on how badly I guess, If its pouring out while its running from about the location your saying, Converter, a little less badly,maybe the front seal?
Either way, sounds like you will be pulling a tranny, best of luck with it
Green Tony!
Ill paint your toenails if you can stand still long enough
Click here to see my Monte build so far
---RIP Robyn Lance---
Top
#259236 - 04/26/10 11:15 PM Re: Badly leaking 700R4 tranny- HELP !! [Re: 7tonemonte]
502ci Offline
MODERATOR in the 11's
Loc: Richfield, Ohio
Sure it would if it's not seated properly...I'm hoping that's your problem so it will be an easy fix.
Bill
Molôn Labe
11.80's at 114 mph, 0-60 in 3.34 sec.____
Click here to see my never ending project
__________Click here to hear it__________
____________RIP Robyn Lance___________
Top
#259441 - 04/27/10 10:37 PM Re: Badly leaking 700R4 tranny- HELP !! [Re: 502ci]
Stroker-383 Offline
Junior Member
Well, I've checked some things today .. While my brother was starting the car, i was checking the tranny etc.
When a gear is selected , ( Drive ), it leaks after about 2 seconds, between the torque converter en tranny.... So i pulled away the tranny and torque converter today ... but how can you see or suspect a broken torque converter or tranny...
The tranny was shifting as lightly as ever , so i dont think thats the problem. Also when i pulled away the tranny from the torque converter ( when the torque convert. was still attached to the startergear) It leaked oil immediatly, and heavy.
After pulling away the tranny and torque converter, i inspected the tranny.. I put it on the ground , facing the oil pan to the floor, and pushed the attachment side ( from tranny to engine ) , downwords , to check if the tranny is leaking ... this wasn't the issue so i'm thinking the torque converter is the problem.. How can i check the Torque converter?
pics coming soon
Top
#259474 - 04/28/10 12:30 AM Re: Badly leaking 700R4 tranny- HELP !! [Re: Stroker-383]
7tonemonte Offline
I had one that was split in my old truck,I think the shop said it was a factory weld, under warranty so it didnt matter to me.
I dont know how to check them, I guess they pressurize it and look for leaks
Green Tony!
Top
#259506 - 04/28/10 02:30 AM Re: Badly leaking 700R4 tranny- HELP !! [Re: 7tonemonte]
Grease Offline
Gold Member
Loc: SanAntonio Fl
The 700 has a bad tendancy to pop the front seal out . So bad in fact the factory makes a seal retainer . The retainer was there fix for the problem . When a 700 family trans is out and apart its common to drill the oil drain hole to a larger size . Sorry I dont have my nots handy just now or I could tell you the drain hole size recommended and the retainer part # . i can try to look them up tomooorow .
Top
#259702 - 04/28/10 11:00 PM Re: Badly leaking 700R4 tranny- HELP !! [Re: Grease]
Stroker-383 Offline
Junior Member
I'm trying to replace the front seal of the tranny first... see if this will solve the problem...
@ grease : Thanks , that would be great!
Top
#259714 - 04/28/10 11:55 PM Re: Badly leaking 700R4 tranny- HELP !! [Re: Stroker-383]
stangeba Offline
Original Owner
Platinum Member
Loc: Shelby Township, Michigan
Check for a hole or crack in the converter. That's where my leak was albeit a TH350.
Good Luck,
Bruce
Original Owner since May 14 1971
Top
#259721 - 04/29/10 12:18 AM Re: Badly leaking 700R4 tranny- HELP !! [Re: stangeba]
Grease Offline
Gold Member
Loc: SanAntonio Fl
Stroker ,if I read my old reciepts correctly the GM part # for the front seal retainer is # 8654491 group # looks like 4.226 . I also use TRANSTAR parts and there part# is 61991 ,which you might be able to purchase at a local tranny shop if you dont have a GM dealer handy .
As to drilling the front seal oil drainback it can ONLY be done with tranny OUT and the PUMP TAKEN APART . In that case it would be drilled .281-.313 (9/32 - 5/16 )
Top
Page 1 of 3 1 2 3 >
Moderator:  black07ss, Grease
Who's Online
0 registered (), 24 Guests and 14 Spiders online.
Key: Admin, Global Mod, Mod
Newest Members
Dakota B, Steve Trout, Logan Spence, Antonio, menace805
4178 Registered Users
Random Gallery Photos
500/thumbs/IMG_0187-1.JPG
by MGD72Monte
587/thumbs/IMG_4932.JPG
by Canuck
500/thumbs/20140202_181720.jpg
by bobsmc
582/thumbs/DSCN1352.JPG
by Riznitch
587/thumbs/IMG_5899.JPG
by Canuck
Top Posters
Sam (Bones) 15547
502ci 14082
7tonemonte 13954
Rob Peters 11844
footballubet 11717
Capri's 71 SS 9817
Mikstudie 9666
Andreas 9302
Jared Richey 9268
Canuck 8955
monte70car 7874
CrazyDavey 7333
Ian 6915
Mo's70MCs 6528
David Mau 6469
wallaby 6323
Monteman1971 6108
72yellowmc,Robyn 6026
Phil 5959
knightfan2691 5663
Shadow Gray SS 5632
savvarock 5441
70mcarlo 5255
black07ss 5075
LostnFound 4686
Mike 57 4291
Chevyss 3980
Kevin Wiles 3791
Leghome 3316
cny first gen 71 3289
stangeba 3264
Heckeng 3154
Forum Stats
4178 Members
44 Forums
11489 Topics
Max Online: 299 @ 11/03/12 06:51 AM
Home Page
Message Forum|Chat Room
Members' Montes|Meet Photos
Tech Info|Museum|Parts and Services|Registry|Links|Contact Us
