Message Board
Welcome!
[clock1]
[clock2]
Home Page | How to Join | Merchandise | Chat Room
West Meet | East Meet | Members' Montes | FGMCC Meet Photos
Tech Info | Museum | Parts and Services | Registry | Links | Club Officers
Topic Options
Rate This Topic
#274669 - 07/30/10 01:23 AM primer
N1RND Offline
Notimeformontework
Junior Member
Loc: Massachusetts
Simple question, when do you use etching primer and when can you use regular primer, like epoxy or urethane?
_________________________
Front-wheel-drive is SO over rated!
Top
#274670 - 07/30/10 01:26 AM Re: primer [Re: N1RND]
bobsmc Offline
bob
Silver Member
Loc: cleveland ohio 44144
etching primer is for bare metal and regular primer is for painted surfaces or body filler etc.
Top
#274713 - 07/30/10 06:32 AM Re: primer [Re: bobsmc]
Slaman Offline
Brass Member
Loc: Southeast Georgia
Epoxy primer is also a direct to metal primer. When reduced it also acts as a sealer. My understanding is epoxy is water-proof thus helps prvent any future rust but it must be top coated as it does not have much UV resistance. My understanding is it can also be difficult to sand. Normally you would use your epoxy or etch primer on the bare metal, followed by your regular primer (2K is better than laquer). Your filler can be applied over epoxy primer btw...
Trigger Lives again!!!
1970, 350/200-4R, TPI, 373:1 Posi 12 bolt, Body Off In Progress
Top
#274720 - 07/30/10 10:36 AM Re: primer [Re: Slaman]
7tonemonte Offline
Its Sooooo GREEN!!
Chrome Member
Loc: Chester County Pa.
Epoxy is about the best thing to use,as stated above,we coat a bare metal car with it,then do bodywork over that. It seals the metal off from any moisture,and protects it under the bondo,if any moisture gets into the bodywork,through a chip or something,it will not get to the metal and start to rust it. The etching primers are not even used at our shop anymore. The urethane primers are high build,for over bodywork,and will absorb moisture over time,and are NOT weatherproof!!
Tony
Montesaurus
Green Means GO
Click here to see my Monte build so far
---RIP Robyn Lance---
Miss You "Old Yeller"
Top
Moderator:  Dan Marsh
Who's Online
8 registered (Canuck, BAMC1369, Chevyss, 70mcarlo, monte70car, Ian, TN454Monte, Andreas), 5 Guests and 6 Spiders online.
Key: Admin, Global Mod, Mod
Who's Chatting
Newest Members
JLP, RDLBOX1970, fistlastgenowne, peter, montefied
3260 Registered Users
Random Gallery Photos
549/thumbs/dsc_0076.jpg
by POE6886
500/thumbs/100_4937.jpg
by Reds72WMonte
549/thumbs/dsc_0082.jpg
by POE6886
500/thumbs/DSCN3392.JPG
by MGD72Monte
500/thumbs/P5310252.JPG
by 72BigBlock
Top Posters
Sam (Bones) 10311
502ci 9669
kc8oye 8770
Rob Peters 8736
7tonemonte 8559
Capri's 71 SS 7599
Mikstudie 7323
Andreas 7323
footballubet 6503
Jared Richey 6285
Allan 6067
72yellowmc,Robyn 6026
monte70car 5750
David Mau 5643
savvarock 5436
Ian 5304
wallaby 5005
knightfan2691 4892
Reds72WMonte 4887
Monteman1971 4881
Phil 4697
Canuck 4539
Kevin Wiles 3486
Mo's70MCs 3343
Shadow Gray SS 3258
alex's72fgmc 2883
Cali4nia Monte 2858
Heckeng 2838
Clock 2549
Chevyss 2516
George Lines 2457
TN454Monte 2319
Forum Stats
3260 Members
35 Forums
6790 Topics
Max Online: 54 @ 09/06/10 11:28 PM
Home Page
Message Forum|Chat Room
Members' Montes|Meet Photos
Tech Info|Museum|Parts and Services|Registry|Links|Contact Us
