Message Board
Welcome!
[clock1]
[clock2]
Home Page  | How to Join  | Merchandise  | Chat Room | West Meet | East Meet | Members' Montes
FGMCC Meet Photos | Tech Info  | Museum  | Parts and Services  | Registry  | Links  | Club Officers
Page 1 of 2 1 2 >
Topic Options
Rate This Topic
#63598 - 03/23/04 06:47 PM How do I install TH350 kickdown cable properly?
ChevroletR Offline
Member
Loc: Mt. Airy, MD
Hello, I have a Edelbrock AVS 650 carb on my 350 in my Monte and I already broke my first kickdown cable right there at the carb. I guess I had it on wrong. I have the cable that has a long slot down it and I put it on by putting a small nut and bolt through it and the carb linkage (same thingy on the carb as with the throttle) but I tightened it to keep it from moving. Someone told me it needs to slide back and fourth but I found even at WOT, its not enough to even budge the kickdown in the trans to kick to passing gear. Can anyone offer any advice to help me with this? Does anyone have any pictures that I could see to see a kickdown cable setup? I'd appreciate any help, thanks.
Ryan Washington
_________________________
www.RyansCustoms.com
'70 Monte 383, 9.0:1, TH350
3,710 lbs Full Tank of Gas
Scat Forged Crank and H-Beam Rods, Four Bolt Splayed Mains
SRP Dished Forged Pistons
Comp Roller 276/282 Adv.-.536/.544 with 1.6 Harland Sharp Rockers
Stock 12 Bolt Open Rear - 2.73's
Best E.T. 13.83 @ 97 MPH
Top
#63599 - 03/23/04 09:01 PM Re: How do I install TH350 kickdown cable properly?
Grease Offline
Gold Member
Loc: SanAntonio Fl
Ryan ....you need to look at the carb you took off. see how far the original hook up point is from the center of the carb shaft . measure the offset if you know what i am saysing.also on the original try to measure the total travel of the pin where the cable hooks up . you need to match as best you can the new carb mounting point , so its like the original . some times the carb company actually sell a kit to make hookup simple for different applications .i'd check with Edelbrock first .
after you have that done then adjust the cable correctly .
mike
Top
#63600 - 03/24/04 11:59 AM Re: How do I install TH350 kickdown cable properly?
BigDaves70Monte Offline
Silver Member
Loc: Tarzana, CA.(L.A. area)
I think Mike is right, go to edelbrock.com, you will find the connection or extension kit you might need, I've seen it there before, also summitracing.com is selling it too.
Top
#63601 - 03/25/04 10:05 PM Re: How do I install TH350 kickdown cable properly?
OutLaw !!! Offline
Bronze Member
Loc: THE DIEING MOTOR CITY.
Ryan lokar makes a nice kickdown cable for your TH350 AND IT'S AJUSTABLE. YOU CAN GET IT AT SUMMIT PART#LOK-KD-2350HT COST 53.95
OUTLAWS PICTURES!!!
(BARREL RACING) rolling over the competition !!!
81 Malibu
383 STROKER
TH 350 3800 Stall
4.56 Posi
Top
#63602 - 05/05/04 05:48 PM Re: How do I install TH350 kickdown cable properly?
nadj Offline
Member
Loc: Elkton, VA, USA
Thanks for the info, I broke mine. Dummy me thought I could adjust the cable at the carb end and snapped that part off from the rest of the cable.
When I bought the car the cable was not connected so I hocked it up and tested it. When I went to full throttle the carb connection never extended enough to pull the cable. I put a wrench to it too adjust the cable and snapped the connecter clean off. Then I went and read the Haynes Manual.
"She's a Monte Carlo and I love her"
Top
#63603 - 05/08/04 05:45 PM Re: How do I install TH350 kickdown cable properly?
Thumper72 Offline
Old Geezer
Junior Member
Loc: N.E. Ga.
Edelbrock sells an extenstion for your kickdown cable part#8012. Not very expensive (under 10 bucks).
"what 'da hell was I thinkin?"
Top
#115479 - 10/19/07 03:06 AM Re: How do I install TH350 kickdown cable properly? [Re: Thumper72]
ChevroletR Offline
Member
Loc: Mt. Airy, MD
Yeah, I went ahead and got the one from Lokar...nice piece. They have a black one and a "stainless" one. I went the cheap route. Thanks guys
Ryan
Top
#115719 - 10/21/07 09:02 PM Re: How do I install TH350 kickdown cable properly? [Re: ChevroletR]
kc8oye Offline
I'm so much cooler online...
Chrome Member
Loc: Roman Forest, Tx
The slot in the cable is designed to SLIDE back and forth on the stud on the carb arm. the idea being that you release the lock on the cable, pull it all the way back, then grab the throttle and pull it full open, and it will adjust the cable into position. That's how it supposed to work in theory.. I've f ound I always needed to pull the cable a bit tighther by hand to get it where I wanted it.
05/10/08 - 14.342 @ 95.21
The loudest sound in the world is a “click” when you need a “bang.”
Top
#115727 - 10/21/07 10:17 PM Re: How do I install TH350 kickdown cable properly? [Re: kc8oye]
ChevroletR Offline
Member
Loc: Mt. Airy, MD
I heard that a mis-adjusted kickdown/detent cable could cause premature transmission failure because of the sloppy shifts. Who wants sloppy shifts?
Top
#115886 - 10/23/07 12:15 AM Re: How do I install TH350 kickdown cable properly? [Re: ChevroletR]
kc8oye Offline
Chrome Member
on a TH350, no.. you can leave the kickdown cable totally disconnected. it does nothing but control shift points. (WOT and 'detent' downshifts)
on a TH350 the vacuum modulator controls shift firmness.. and by nature of it's design, if it's disconnected, the trans goes to 'wot' mode all the time.. VERY hard, VERY late shifts (ask me how I know)
on a 700r4 with a "TV Cable" (not kickdown) yes, not having it adjusted right can quickly wipe the clutches out from too little line pressure. a 700r4 does not use a vacuum modulator.
Top
Page 1 of 2 1 2 >
Moderator:  black07ss, Grease
Who's Online
7 registered (72jrfan88, Sam (Bones), Leghome, ripleydale, black07ss, Jared Richey, 71 monte project), 32 Guests and 104 Spiders online.
Key: Admin, Global Mod, Mod
Newest Members
Newt, pgkidd, Gabe 70, Dakota B, Steve Trout
4181 Registered Users
Random Gallery Photos
701/thumbs/012_2_.JPG
by Canuck
539/thumbs/IMG_3085.jpg
by Vaughn
500/thumbs/Monte_--_Befor_After_Small.jpg
by Alize LowRod
620/thumbs/DSCN0224.JPG
by Andreas
578/thumbs/Scan_Pic0001.jpg
by Katman
Top Posters
Sam (Bones) 15563
502ci 14092
7tonemonte 13971
Rob Peters 11869
footballubet 11739
Capri's 71 SS 9824
Mikstudie 9672
Andreas 9341
Jared Richey 9275
Canuck 9009
monte70car 7879
CrazyDavey 7333
Ian 6918
Mo's70MCs 6533
David Mau 6469
wallaby 6328
Monteman1971 6110
72yellowmc,Robyn 6026
Phil 5960
knightfan2691 5663
Shadow Gray SS 5632
savvarock 5441
70mcarlo 5268
black07ss 5091
LostnFound 4734
Mike 57 4291
Chevyss 3980
Kevin Wiles 3791
Leghome 3336
cny first gen 71 3304
stangeba 3273
Heckeng 3154
Forum Stats
4181 Members
44 Forums
11556 Topics
Max Online: 299 @ 11/03/12 06:51 AM
Home Page
Message Forum|Chat Room
Members' Montes|Meet Photos
Tech Info|Museum|Parts and Services|Registry|Links|Contact Us
