Mike Brichta Posted August 10, 2014 Share Posted August 10, 2014 I am interested in doing a cam upgrade to my zz4 engine and was wondering if anyone out there has done this already. I was at a cruise last night and was talking to a guy who has a zz4 engine that had a cam upgrade done and he said he gained around 60hp but doesn't know any of the details. He said he had the following done to his stock zz4 engine: - replaced the cam - added roller rockers - switched the intake Anyone know where I can find out what my options are? Thanks!! Mike Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted August 11, 2014 Share Posted August 11, 2014 a different cam and intake would make a big difference ZZ4 350 TURN-KEY TECH SPECS Part Number: 19201330 Engine Type: Chevy Small-Block V-8 Displacement (cu. in.): 350 Bore x Stroke (in.): 4.000 x 3.480 Block (P/N 10105123): Cast-iron with four-bolt main caps Crankshaft (P/N 12556307): Forged steel Connecting Rods (P/N 10108688): Powdered metal steel Pistons (P/N 10159436): High-silicon aluminum with offset pins Camshaft Type (P/N 10185071): Steel hydraulic roller Camshaft Lift (in.): .474 intake / .510 exhaust Camshaft Duration (@.050 in.): 208° intake / 221° exhaust Cylinder Heads (P/N 12556463): Aluminum; 58-cc chambers Valve Size (in.): 1.940 intake / 1.500 exhaust Compression Ratio: 10:1 Rocker Arms (P/N 10089648): Stamped steel Rocker Arm Ratio: 1.5:1 Recommended Fuel: 92 octane Ignition Timing: Base 10° BTDC, 32° Total Maximum Recommended rpm: 5800 Balanced: External Quote Link to comment Share on other sites More sharing options...
Mike Brichta Posted August 11, 2014 Author Share Posted August 11, 2014 Hey Sam, The previous owner already switched the intake to a Dart intake so I will probably keep that on the engine. What would you recommend for a cam? I see lots of guys use Voodoo and Lunati. Any thoughts? Thanks!! Mike Quote Link to comment Share on other sites More sharing options...
Jason72 Posted August 12, 2014 Share Posted August 12, 2014 Mike, I have a gm hot cam and a set of 1.6 scorpion narrow body rollers and the springs slightly used I would be willing to part with... Quote Link to comment Share on other sites More sharing options...
