Droff Posted October 15, 2014 Share Posted October 15, 2014 I've been working on installing a front suspension kit, just getting to the part where it all goes back together. I installed the sway bar, tightened but didn't torque the bushing bolts and then looked at the sway bar connectors on the lower A-arm. Now the connectors aren't torqued down at all and not really tight but the connector bolt head is pretty much touching the upper ball joint nut on the upper A-arm. Am I to assume this won't be an issue once I get the sway bar connector tightened correctly - as in, not touching each other? Thanks. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 15, 2014 Share Posted October 15, 2014 once you put weight on the suspension it will move away, some of this aftermarket stuff is just wrong, the spacer and bolt are a little wrong, that happened to me too, but as soon as the suspension starts to compress, the ball joint swings out Quote Link to comment Share on other sites More sharing options...
Droff Posted October 15, 2014 Author Share Posted October 15, 2014 Thanks Quote Link to comment Share on other sites More sharing options...
