Body Mount Dilemma
MC-71
I know I just opened a whole can of worms. I started body mounts while the car is still on the frame. My Monte is finished on the exterior. I know this is not going to be easy. I don't have a problem in getting all the bolts out. One side at a time. My only real concern is if the top of the frame might be rotted. Could I get away with a 1 1/2 ID washer but sitting on top of the frame. Those washers are about 1/8" thick. The other problem is when doing that the bottom rubber is going to mate up to the top rubber a 1/8" shorter. Also I think I will take both doors off and leave the nose on. Input will really HELP!
Carl
Sam.  Should I pull the nose. I'm afraid the fenders will be into the doors. What do you think?
Maybe I can move the doors back to the quarter panels. Then readjust after the new mounts are in.
Carl
So you are saying to leave everything the way it is and carefully lift the body on one side and then the other side. I "Think I Need A Bigger Boat". I can do it. Thanks for the Help Sam.
Carl
I am in the process of R&R my body mounts also with body on frame. My plan is to do what Sam said. I plan to support car at 4 places, one side at a time. Radiator support, on the rocker at the door and fender, at the rear of the rocker and overlap  where the door and 1/4 panel meet, and at the rear of car. At the two points on the rocker panel will use floor jacks with two foot 2x4s or 4x4s. Haven't decided which ones yet but that should give enough support to R&R bushings. Going to take it slow and careful.
John S
I found this tip on the Chevelle site. Use a 4x4 under the rocker but run your circular saw right down the top of it. Measure the depth of the pinch well and put that cut out right into it. Just like setting a newer car on a frame machine.
My car is a "Salter" and my bolts are not coming out easy. I have drilled a 2" hole a little off center of the body bolt. I'm trashing all the caged nuts and using new square nuts and caping the holes with a hole plug. My 71 is 44 years old. This needs to be done.
You can go on the www.teamchevelle.com and search Body Bolt Length on pg one you will find a PDF by a member telling how he did what I mentioned above. Thanks for all the help.
Carl
Open the PDF on post #12 above this post.
Scott I'm not taking my body off. Just lifting it 1 1/2" to 2". I'm going with the pinch weld with the saw cut in the 4x4. "BUTTER"
Carl
I've done this twice now, once on a lift that was pretty easy and once on the ground with jacks. The lift way is way is best, just use the lift pads on the pinch welds, loosen bolts and lift only enough to sneak out all the mounts at once.
Watch for the nose moving or flexing as the weight of the nose will flex the front tip of the frame some.
Second time was with 2 jacks and 4 stands I did it with 2x10's cut to the right length and jacked on the supports on the floors (front and rear farthest distance I could to spread the load) but didn't have the motor/trans in that time. If the motor is in the floor pans will more then likely flex if you don't watch out.
That is why I used 2x10's so I had more surface area touching. This is my experience but ever car is different
  • 3 weeks later...
Replaced body mounts Sat. Used two 2x4's screwed together with drywall screws 32" long each to lift car. Cut a channel 1" from the edge 3/4" deep and 1/4" wide on each piece. The pinchweld flange fit into the channel, and a cut out was made for the fender bolt as the lumber overlapped the fender. I did not lift by the flange, instead the channel prevented the lumber from slipping. The majority of the lift was by the two floor jacks under the rocker and the jack under the radiator support was used simply as support, not to lift. The bottle jack at the rear bumper was used to lift minimally. Throughout the procedure the door gaps did not change as I was very careful to keep an eye on it. took about 2 hrs. not bad for a Sat morning.
John S
The only issue I had with replacing the bushing mounts on my 70 were at the very rear. The cages for the square nuts broke loose. So I had to cut into the rear pan support to get at the nuts. Then I just welded back up my cuts.
Hey John. I see you did what I had posted. How did it go. Was there any problems using that method with the pinchweld. Did the body come up easy or hard. Thanks for posting the pictures.
Carl
Body came up very easy Carl. At the rear mount I used a pry bar against the body to break free from the mounts other than that very simple. It seems like the rear of frame has some flex to it. I also replaced radiator support bushings and measured from support to fixed spot on frame. If the support moves sideways it can mess up the fender and hood gaps. Also with the new bushings in body in place it raised body 1/8" probably due to compression of old bushings.
John S
