lance15301 Posted November 2, 2015 Share Posted November 2, 2015 I have been trying to find this for the last month now and cant seem to find any opinion on it. I have a 1971 monte carlo I have the fenders and all that off so im going to replace the body mounts. i cant find the round metal parts of the mount. I was told that a chevelle and a monte carlo have the same mounts. some websites say that they will interchange and others do not. I was thinking of getting this kit for the monte http://www.summitracing.com/parts/ens-3-4170r any idea if these will work or not? Quote Link to comment Share on other sites More sharing options...
Vinniepooh Posted November 2, 2015 Share Posted November 2, 2015 Looks like that kit will leave you short a few mounts. I recently installed the 3-4134R kit but it is a bushing only kit. Core support = 2 Firewall =4 Driver's seat area =2 Rear seat area =2 Rear of frame behind axle =4 Total = 14 (plus 2 pucks over axle not included in Energy suspension kits, I used ones from a partial stock kit that I had) Quote Link to comment Share on other sites More sharing options...
lance15301 Posted November 2, 2015 Author Share Posted November 2, 2015 i alreadys have my core support bushing im just worried about the actual body mounts and if these will fit. Quote Link to comment Share on other sites More sharing options...
LostnFound Posted November 2, 2015 Share Posted November 2, 2015 Here's a thread from a while back on the subject. http://www.firstgenmc.com/forums/index.php?/topic/12027-body-mount-bolts/?hl=%2Bbody+%2Bmounts Quote Link to comment Share on other sites More sharing options...
John S Posted November 2, 2015 Share Posted November 2, 2015 The bushings from OPGI have the sleeves in them as do Inline tube. As far as the bolts go you will need 12) 2 3/4" bolts for the body 2) 3 1/4" bolts for the radiator support. Keep this in mind, the two bolts under the drivers and passenger seat should have 1/4" cut off those bolts. When I did mine the 2 3/4" bolts under the seat poked thru the floor pan even though there is a raised portion of the floor pan to accommodate it. So keep that in mind for those two bolts only. I believe the factory bolts are 2 1/2 or 2 5/8 in long for those two bolts. John S Quote Link to comment Share on other sites More sharing options...
lance15301 Posted November 3, 2015 Author Share Posted November 3, 2015 thanks for the reply guys. i called luttys chevy garage since they are right up the road from me. Greg helped me out a bunch. he said that the monte and chevelle mountsa re the same. the only reason i am going with poly mounts instead of rubber is because this will be a road racer/street car. Quote Link to comment Share on other sites More sharing options...
